Lets do the twist!
By gizmo, Section Wind
Posted on Sun Jun 13th, 2004 at 05:55:27 AM MST
Shaping blades with twist worth the effort.
I have a testing windmill with a set of 3 plywood blades. Each blade is approx 1 meter long and 18mm thick. Front is flat, back has a basic aerofoil shape. The blades were angled at approx 15 degrees.
These blades have been in use for over 12 months and survived a tower fall 9 months ago.
I tilted the windmill down to try a new lighter steel propeller hub that I lasercut a few days ago. Recently I had read an article about blade twist and the effects of stalling blade tips at high speed, so I decided to fire up the power plane and reshape the blades to provide 5 degrees of twist at the tips while keeping the original 15 degrees at the centers.
A quick coat of paint and the windmill was back up in the air. Straight away I noticed a dramatic increase in speed, and less noise. Giving the blades a bit of twist has made a big difference in performance.
My next set of blades will definately have the correct twist angles, the gains are worth the extra work involved.
I've taken some photos of the new propeller hub, will put on my website in the next few days.
http://www.thebackshed.com
Glenn
Lets do the twist! | 1 comment (1 topical, 0 editorial)
Re: Lets do the twist! (none / 0) (#1)
by hvirtane (hannu_markus_virtanen(at)yahoo(dot)com) on Sun Jun 13th, 2004 at 02:40:36 PM MST
I looked at your site.
Really nice pictures and descriptions
how to make the machine
you have got there.
Thank you a lot for sharing all
you constructions and the working
methods of yours.
I think that your original blades
without twist were with quite high
pitch angle. Did you try with
7 - 8 degrees?
However I think that with twisted
blades the result will be better.
Have you tried with that F & P
generator to put two of them
on the same axle?
You might easily build a
machine with 1 kW power if
you put three of them...
  126 Scoop users have viewed this posting.
· http://www.thebackshed.com
· Also by gizmo
