Can I charge a 12v battery with a 9v power source
By kurt, Section Homebrewed Electricity FAQ
Posted on Wed Jun 02, 2004 at 03:29:30 AM MST
no current will flow into the battery until the voltage from the charger exceeds the voltage of the battery
Think of volts as pressure and amps/current as volume and watts as mass
No current (volume) will flow into a battery until the source voltage exceeds the battery voltage (pressure). That would be like trying to add air to a car tire inflated to 35 psi with an air source of 20 psi you could leave the air source hooked to the tire all day and no air would flow into the tire because you would not have the pressure to push the air in.
Can I charge a 12v battery with a 9v power source | 0 comments (0 topical)
  115 Scoop users have viewed this posting.
· Also by kurt
