| Hi
Well here is my 8" version. First used 5" dia and 6 coils of #32 wire of 200 turns. all single phase. Was impressed of the voltage output but low current. At about 10-15mph I could charge a 12v battery at 140ma. I put holes in airfoil to make light as possible. And used R/C cover in center nice pink shade. Worked not to bad.
Then made a wood 5" and cut out each little traingle and glued on wood plate. did a little router work. This time used 28 # wire and each phase had 47 turns or loops. Used the magnetic layout and wired it up as 3 phase. Was not to happy with results at a 10mph was only getting about 6 volts. Drove car to 40mph and got 13volts with short circuit test got .5amp. So about 6 watts for this unit. Was trying to follow Ed's stator maybe my dia is to small. But have a look. The turbine is on a zinc shaft with 5/16 bearings. Sorry no large pic will post later I forgot.
Wayne |
145 Scoop users have viewed this posting.
