all geared up !!
By hiker, Section Homebrewed Electricity
Posted on Sat Jul 10th, 2004 at 10:52:08 PM MST
all geared up and all quilled up
just a shot of my little ceramic mag alt--added some parts to it from an old ten speed bike--in the process of making a 8 by 10 blade for it--my little 2 by 4 blade
plus house moulding blade just didnt have the guts for it..
all geared up !! | 8 comments (8 topical, 0 editorial)
Re: all geared up !! (3.00 / 0) (#1)
by hiker (hiker.wild[at]yahoo[dot]com) on Sat Jul 10th, 2004 at 10:56:04 PM MST
and this guy here--third time around--3 hours of pulling quills!!!
hes a great dog--but im beganing to wounder if he has any brain cells at all !!
WILD IN ALASKA
Re: all geared up !! (3.00 / 0) (#2)
by tecker on Sun Jul 11th, 2004 at 07:04:46 AM MST
   Looks like the rabbit got away . put the small spoket to the bottom. and put in an adjustment to tighten the chain. Looks good
Re: all geared up !! (3.00 / 0) (#4)
by hiker (hiker.wild[at]yahoo[dot]com) on Sun Jul 11th, 2004 at 12:44:38 PM MST
with the bigger blade i most likly will drop it down to the smaller sproket..
it just worked better at the setting its on  now with my smaller blades..
i have a chain breaker tool--so its real easy to set the chain for diffrent
settings--if this works i'll try it on my bigger alt.--dog is doing great today..
time to hit the trail--later..
WILD IN ALASKA
Re: all geared up !! (3.00 / 0) (#7)
by Norm (peppysue@suite224.net) on Sun Jul 11th, 2004 at 08:54:19 PM MST
i have a chain breaker tool--so its real easy to set the chain for diffrent settings-
 chain breaker tool...(yeah me too ) 3rd one before I learned how to use without breaking it...
 Walmart ((made in China)...dropping prices every day) (gag!)
               ( :>) Norm
( :>) Norm
Re: all geared up !! (3.00 / 0) (#3)
by BrianK on Sun Jul 11th, 2004 at 11:39:35 AM MST
ouch to the dog let us know how well that works  I have been told that you loose a lot of eff. in the gears
Re: all geared up !! (3.00 / 0) (#5)
by hiker (hiker.wild[at]yahoo[dot]com) on Sun Jul 11th, 2004 at 12:54:54 PM MST
a bit more drag--so it takes a little more wind speed to get it started--once its
started thou it really kickes in--my bigger blade should really help out![8ftby10"]
WILD IN ALASKA
Re: all geared up !! (3.00 / 0) (#6)
by BT Humble (bt_humble@bigpond.com) on Sun Jul 11th, 2004 at 04:49:20 PM MST
If you salvaged the gears from an old bike, maybe you can arrange the derailleur and a long cable to change the gearing from the ground? ;-)
I'd suggest using some motorcycle chain lube (I recommend PJ1 Blue) to minimise the frictional losses & keep it running quietly.  That stuff also won't flick off the chain and make a mess of your blades/tower/RV/etc.
Poor Doggles!  I hope he's feeling better today.
BTH
Re: all geared up !! (3.00 / 0) (#8)
by hiker (hiker.wild[at]yahoo[dot]com) on Sun Jul 11th, 2004 at 11:41:03 PM MST
thought of that--but the derailleur would be way to much extra drag--at least
for my setup...
WILD IN ALASKA
  102 Scoop users have viewed this posting.
· Also by hiker
