I've come up with a design that has quite a few flaws I'm sure but it looks kool :P
I'm using a ' 59" hornet' turbine on the back but not sure what I should do for the front turbine. I was thinking of using 3 replacement blades from and Air-X as they are smaller but I'm concerned with the how much wind they may block from the rear turbine so I may just get another set of hornet blades and cut them to size. They would be counter rotating so that should reduce the effect of power loss of the rear turbine caused by cavitation.
In my 'pipedream' the front generator is supposed to be for Low wind, producing 12+ volts at 3-5 mph so it can generate at least something when it is just breezy while the rear should start at 5+ mph and generate how ever much it can etc (suggestions welcome as for the rear generator size!)
This thing will auto furl by the use of a flexible hub made from ???? I'm not sure of yet. I was thinking of multi layers of spring steel, (like the stuff they use in the bottom of jungle boots) or perhaps Aircraft aluminum that would allow some flex in high/damaging winds. Also because the front turbine is further away from the yaw bearing than the rear, the entire body may, during high winds, turn to the side a litle bit reducing the blade angle also.
Another problem I havent figured out is, how to get power from both of them at the same time. For instance if in a 5mph wind the front 30 VDC servo is generating 12 volts and the rear is generating like 9 volts they would be not only different voltages but they would also be out of phase so I cant just wire + to + and - to - and use one set of wires down my pole. I guess I would need some sort of charge controller inside the body pipe? (suggestions welcome)
I don't know much about this as you can probably tell and this is my first try, but I am pretty tough skinned so any comments/suggestions would certainly be appreciated.
Thanks! Follow this link for a clearer picture
136 Scoop users have viewed this posting.
