TDM on Roof Gable?
By eformx, Section Wind
Posted on Mon Jul 26th, 2004 at 10:23:21 PM MST
Can a TDM on a short pole be mounted to a Roof Gable? How will it hold up? Issues?
I have just put up an Ametek TDM with 4 PVC blades.  The blade length is 45 inches.  The setup is sitting on a 4 foot 1.25 inch diameter pole.  Its attached to the gable with an Eave Mount.  The Eave Mount has 2 brackets, 1 is 30 inches in length, it is in general designed to support a TV antenna.
The TDM uses a Flange Bearing mounted to the pole, so the whole thing with the tail flys into the wind.  In the Ottawa Valley (Canada) the trees are shorter than the height of the roof.
This is a great web site and I think if the masses are to pick-up on generating their own electricity we need to try standard mounting locations.
My question is, has anyone done this before, has anyone mounted a TDM on a gable, and how has it held up?  I am not using any guy wires, just the eave mount.  If there are vibrations (none felt yet), is their options to isolating them?
If trees are not an obstacle, is the roof a good place?
Thoughts?
Ps. Should have a picture later today.
TDM on Roof Gable? | 3 comments (3 topical, 0 editorial)
Re: TDM on Roof Gable? (3.00 / 0) (#1)
by Jerry on Mon Jul 26th, 2004 at 10:51:30 PM MST
Hi eformx
I've flown small gennies that way with no problem. However the winds in that location have never ecceded 35 mph.
Airheads Page
Re: TDM on Roof Gable? (3.00 / 0) (#2)
by Ungrounded Lightning Rod on Tue Jul 27th, 2004 at 12:34:21 AM MST
Several issues should be addressed:
First:  Strength.  Eave mounts are intended to support an antenna against the antenna's wind load.  A mill produces a HECK of a lot more wind load.  In your case that wind load is at the 4-foot end of a lever.  The other end of the lever is the separation between the upper and lower mounts.   If that's, say, two feet, you've just doubled the force trying to pull the lower mount's screws out of the wall.
Another strength issue is the pole itself.  The bending moment in the region of the upper mount is enormous.  Too much load and it folds there.  Result is your mill (which is probably overspeeding, too, since it just got hit by a gust and hasn't had a chance to feather yet) comes down on the roof or side of the house with the blades at wind load speed times the TSR.
Say your TSR is 6 and your wind is 100 MPH:  Your house gets hit with a pvc wedge traveling at nearly the speed of sound.  NOT good for the shingles - or the underlay, or the roof joists.  (And it's probably raining REAL hard, or will be in a couple minutes.)  That's assuming it hits the roof, of course.  If it hits a window you could have the blade snap off against the frame and travel across the room at maybe 400 MPH, accompanies by the window glass.
Guy wires take this bending load off the pole, substituting a smaller one higher up.  Do it right and your main storm worry is a blade coming off when it's traveling toward the house.  (That's why I'd use a tower rather than an eaves mount.  But then I tend to live in places with violent winds from time to time.)
I'd expect a PVC mill to be much less of a hazard than a wooden one in these situations.  Less tendency to snap, lower density material so it loses a lot more momentum when hitting the house.  (And with a commercial design rather than homebrew perhaps the designers did some serious multi-head design work on failure mechanisms. Maybe.)
Last is vibration:  Mounting a mill on the eaves means any vibration it generates is transferred to your walls.  This can make annoying sounds.  But a bigger issue is that it can work nails and screws loose over time.  Working nails loose in the house leads to leaks and damage - sometimes in places where it's expensive to fix.  Working the mount fasteners loose means that somewhere down the road one of the mounts is likely to pull loose in high winds, leading to scenarios like those above (but with less energy in the blades.)
Re: TDM on Roof Gable? (3.00 / 0) (#3)
by hiker (hiker(at)adnmail.com) on Wed Jul 28th, 2004 at 01:59:03 AM MST
good point there about vibration..
i had my 19.5ft cb. antenna mount to my concrete block chimmny.
it was up there for years, never really did worry about it.
after all it was mounted  to somthing soild right!!
well a big wind came along[not the first one]..
sitting in the house watching my batt. powered tv[power knock out].
then all of a sudden i here this huge crashing bangin sound ..the whole
house shakes--thought the roof was breakin loose..
ran outside--there lay the block chimmny and the remains of my cb. antenna- what happend over the years with the antenna waving back and forth in the wind it slowly
cracked the morter--AND THEN DOWN IT CAME......dangggggg.
WILD IN ALASKA
  86 Scoop users have viewed this posting.
· Also by eformx
