| I'm in the process of building a new, low-amp PMA (non-wind related) and after several days of looking for a suitable material for the magnet disk, that little voice in my head told me to go browse the Grainger catalog. As fate would have it, I found a 14" sheave (pulley) for a mere $20 (the catalog number is 1L847). Here's the catch: I want to orient the magnets axially, i.e., pole faces parallel to the shaft. In order to do this, I'd have to attach some kind of a ring made from wood, plastic, etc., 1/2" or 3/4" thick, to the perimeter of the sheave. So... I went nuts all afternoon trying to come up with a way to do this. I came up with two possibilities:
- Cast a one-piece ring using an appropriate casting resin (which sounds very messy and since I've never done it before, I'd probably be getting in way over my head, and
- Cut a ring from MDF, particle board or industrial plastic and attach it to the sheave.
The outer portion of the sheave is basically a V-groove and drilling through it radially is probably out of the question. The only method of attachment I can see is to drill very small holes through the side walls, drill matching holes through the thickness of the ring, and then basically "lace" it on with fine steel wire.
I thought about milling the inner portion of the ring to match the V-groove, but that presents two problems: 1) the ring would have to be cut in half (across the diameter) and then glued back together -- mechanically speaking, a disaster waiting to happen! and 2) cutting the matching profile would be exceedingly difficult.
Using the sheave eliminates a LOT of work and machining, i.e., making a hub, getting all the pieces square to the shaft, etc., but it also creates a real challenge in mounting the magnets (cylinder-shaped, 1" diameter, 3/4" long).
So...now that my brain has become a little puddle of goo, perhaps one of you will see an amazingly simple solution that eluded me all day...
-Chris-
92 Scoop users have viewed this posting.
