just a test set up--8 coils inlaid in 3/4" plywood--85 windings -with a mixture of
15-17 gauge wire--8 mags per rotor[double stacked=16 per rotor]topped off with harddrive mags[only on one rotor-ran out] total of 32 ceramics,,
open volts 50 plus--with all coils in series-10 plus amps..
with stator split in half and rectified and two halfs in pararell 20 plus amps-25Vs.
when i hook it to a 220 to 110 converter backwards i get about 100Vs.only 200watts max.[with all coils in series]..
hits 12volts at a slow speed when all coils are hooked in series--not much more speed is needed when hooked up with the stator split in half..
used a 110v handdrill for all the results..
i think thats about all those ceramics have to offer[with this setup].
TIME TO BREAK OUT THE CHECK BOOK AND ORDER SOME NEOes..
later..
122 Scoop users have viewed this posting.
