I'm planning to buy a solar hot water system, made here in Australia by Edson hot water systems. They recommend the use of frost valves rather than a glycol based antifreeze system to protect the panels from ice damage.
These work a bit like a car thermostat in reverse; when the temperature drops to 0*C (32*F) they open enough to drain the near-freezing water out of the collector panels, replacing it with hot water from the storage tank and then closing when the panels warm up a bit.
The water loss isn't an issue as we're using rainwater collected from the roof the panels will be mounted on, and we will be using a water jacket in the fireplace to provide most of the hot water in winter.
Most winter nights here don't get below freezing. A really cold night woulg be -4*C (24*F?) and if I plan for a worst case of -7 or -8*C (16*F?) I should be ok.
Does anyone here have any experience with frost valves? I guess my main worry is reliability, if they fail to open they could ruin my (expensive) panels ( 3 panels, 4'x8', about A$750, US$550/panel). The supplier says they're fine, and I have no reason to doubt him , I just like to be as fully informed as possible before parting with my hard-earned money.
Thanks in advance for any help, and I'd be happy to go into more detail about the system if anyone's interested.
Paul. |
62 Scoop users have viewed this posting.
