| These diary threads are solely for the benifit of those that want to build "alternative" energy systems OR those that just want to dabble with something that's a bit out-of-the-ordinary.
I would greatly appreciate it if anyone has ANYTHING NEGATIVE to say, PLEASE REFRAIN FROM POSTING IT TO THESE DIARY THREADS. If you wish to attack the material, please do it in another message group like the "Rants" forum. I think that's probably what it's for anyway. If you possess even an ounce of human courtesy, you'll comply.
I don't wish to trouble the Admin (or me or anyone else) further by participating in any more attack threads.
I've seen some Bedini motor stuff posted so I'll tell you a couple of basic improvements that are needed in what I've seen built here.
For anyone deciding to try a Bedini model:
1. Use a very large flywheel mass and a very free-wheeling bearing on the axle. If a flick of the finger doesn't produce a nice long slow spin-time, it won't work right. The flywheel mass not only smooths out the motor, it is needed to absorb and hold angular momentum without losing any between pulses on the stator.
So, a basic "roller skate" wheel is not usually the best choice, since it has very little inertial mass in relation to it's bearing friction.
- The transistor turns on by sensing the incoming magnetic field via a positive going voltage. So the transistor gain must be high enough to allow this small signal to turn it on. A 2N3055 is usually quite sufficient, although I've seen a couple of others mentioned that would probably work "ok". The 2N3055 is ubiquitous, cheap, and in most cases, sensitive enough to do a good job in that application.
- There must be a sufficient number of windings on the stator core to induce a sufficient voltage to trigger the transistor base-emitter junction.
Some pics will be coming along shortly.... |
88 Scoop users have viewed this posting.
