| Well, When I first got into this stuff, I knew nothing about anything concerning making my own electricity and I have been learning as I go. I thought that going with a 12 volt sytem was the most cost efficient way to go, since there was plenty of lights available for cheap at 12 volt, and most equipment such as radios, flash lights and scanners that I could purchase was 12 volt anyway etc.....
So, I purchased the air industrial (12 volt), I have an air x (that (I am going to have fun hitting with a sledge hammer, because it has given me nothing but problems)and some older solar panels (12 volt) and one newer one (17 volt). I have 4 trojan batteries that I have wired up for 12 volt charging and I have a charge controller that can charge 12, 24 or 48 volt.
OK... so now, enter the Sunfrost fridgerator and freezer. Inside the controler box for this thing, they have built in a cutoff switch that will cut the refridgerator off at 7.6 volts and will not turn the fridge on again until 11V.
The problem I am having is that I cannot get this thing to run long enough with my 12 volt system unless I am basically fully charged, which isnt happening for me because I am not producing this much power. Has anyone ran into this problem?
Am I going to have to start over again and charge 24 or 48 volt to get this thing running correctly?
Can I solve this problem by adding another 12 volt wind generator to keep my batteries full or will I need to stop what I am doing with this system and start working on a 24 volt?
This is going to mean that I have to purchase new wind generators (or build some which I am doing right now anyway, but my design is also set up for 12 v, so I will have to change it a little) unless there is a way to change my air industrial to a 24 volt system, but I do not think that this is possible, at least I have found no documentation on how to do this.
Does anyone have any suggestions?
Devon |
70 Scoop users have viewed this posting.
