It sounds to me like your waterpipe from your pump either has a hole in it in the well, or else the coupling to the pump itself is breaking loose .
If you pull the cap off the wellhead and open a faucet, you might hear the leak (if it's above the water level). It's doubtfull the pump is bad!!
If you need to pull the pump, it helps to have a helper. Two people can easily do it. Just kill the power, unscrew the three wirenuts at the wellhead, and use a tee bar (you can make one) to screw into the pitless adapter. After that, it's just a few minutes of grunting work to pull the pipe and pump out. One person will need to walk the pipe away from the well (so no kinks in the black pipe). Every 20' or so there SHOULD be a disc to keep your wire and the pipe from rubbing the well sides. I'm betting someone um forgot to put these on. Just above the pump there NEEDS to be a rubber expandable torque arrester to keep the pump from spinning on startup. This should be adjusted as you start to drop your pump back down the casing... snug but not that you need to push the pipe down. Check for rubbed wires while you have the pipe out, an ounce of prevention you know...Sorry this is so long, (ex well driller here) hope you find an easy fix. Gary D. |
87 Scoop users have viewed this posting.
