FWD hub for wind gen?
By whatsnext, Section Homebrewed Electricity
Posted on Wed Sep 29, 2004 at 10:01:48 PM MST
An idea for Zubbly
I was thinking today as I read Zubbly's alt post about using a FWD spindle for a wind gen. I know the Dans like the Volvo rotors but if you modified the outer CV joint on a FWD hub so that it was much shorter and teminated with a Lovejoy connection you could insert different alts at will simply by removing one alt and replacing with another without touching your blades. Looking at the bearings in a typical alternator it does not look like they are really set up to carry the load of a prop. If you seperate the prop loads from your alt your alt bearings would probably last a long time.  For a real mega alt using a full floating rear hub from a one ton axle to support your prop would probably allow for a giant prop to run very reliably.
Just a thought, John.......
FWD hub for wind gen? | 6 comments (6 topical)
Re: FWD hub for wind gen? (3.00 / 0) (#1)
by Jerry on Wed Sep 29, 2004 at 10:32:45 PM MST
Hi John
I've been flying a car alt as a wind genny for 3 years now. Its still going strong. the blades are direct mounted.
Airheads Page
Re: FWD hub for wind gen? (3.00 / 0) (#2)
by John II on Thu Sep 30, 2004 at 08:06:49 AM MST
HI Whatsnext: I like the idea though. It's especially a good idea if one were toying with a much larger wind generator. You don't have your pivot offset, so you would have to use some other means of high winds governor.
John II
Re: FWD hub for wind gen? (3.00 / 0) (#3)
by zubbly on Thu Sep 30, 2004 at 04:36:16 PM MST
Hi Whatsnext!
i didn't make a post about using a FWD spindle on a genny.   :)
zubbly
Re: FWD hub for wind gen? (3.00 / 0) (#4)
by whatsnext on Thu Sep 30, 2004 at 08:28:15 PM MST
Zubbly, I know that. That's why I made the post. I thought that since you seem to make a lot of different alts that it might be a good idea, for you, to make a wind mill that allowed for quick change alts.
John........
Re: FWD hub for wind gen? (3.00 / 0) (#5)
by zubbly on Fri Oct 01, 2004 at 04:54:08 PM MST
Hi Whatsnext!
sorry i misinterpreted your post. just pretty tired sometimes when i read them.
i do appreciate your idea very much, and the idea of a quick change assembly is an excellent idea as i am always dabling in a few different areas.
thanks again!
zubbly
Re: FWD hub for wind gen? (3.00 / 0) (#6)
by whatsnext on Sat Oct 02, 2004 at 01:06:54 PM MST
Zubbly, Any time. I realise that your different alts would need to be pretty similar to be using the same set of blades but still the idea of a quick change set up seemed kind of nice when it first came to me.
Please keep s informed of the progress on the alt conversion. Where I work we send out about 400/year to get rebuilt. I'm going to give the rebuilder a call to see if he has any ideas.
John........
· Also by whatsnext
