Boost Converter Plans
By DanOpto, Section Controls
Posted on Sat Sep 4th, 2004 at 06:01:05 AM MST
Here is a link for a 12 to 24 volt boost converter.
http://www.acs.comcen.com.au/12_24reg.html
Boost Converter Plans | 3 comments (3 topical, 0 editorial)
Re: Boost Converter Plans (3.00 / 0) (#1)
by LEXX on Sat Sep 4th, 2004 at 07:23:43 AM MST
I am a total noob when it comes to electronics, but I hope to learn some.  Would something like this be usable with a rectified windmill?  I noticed that the unit had a system for "turning off" the solar panels, this wouldn't work for a windmill so would it need a load diverter before the unit, or am I comparing apples and oranges?
LEXX
Boost Converter Plans - Matching Load to Gen (3.00 / 0) (#2)
by DanOpto on Sat Sep 4th, 2004 at 09:09:45 AM MST
This could be used to stabilize the voltage output of a rectified mill.
The mill output would be rectified and fed into a very large capacitor that would act as a float storage.
The converter would then dymamically convert the output to a higher voltage to match a higher voltage load that needed an even voltage for it's supply.
You would still need a dump load to absorb over production but the higher voltage would make it easier to match loads.
Re: Boost Converter Plans - Matching Load to Gen (3.00 / 0) (#3)
by LEXX on Mon Sep 6th, 2004 at 07:54:37 PM MST
Thanks Dan.
  74 Scoop users have viewed this posting.
· http://www.acs.comcen.com.au/1 2_24reg.html
· Also by DanOpto
