Lorentz force and right hand rule
By tecker, Section Homebrewed Electricity
Posted on Mon Sep 6th, 2004 at 03:20:43 PM MST
  Matching magnetic force with the direction of winding and  rotor direction
  The equations are not to important as there is more fun in playing around with making juice but I though I 'd post this link for those thatare interested .I think after all is said and done the main objective to designing coils is to match the magnetic force
direction with the direction of revolution with resect to the winding and have the winding as straight as posible thru the nort to south magnetic  flow .
   IE large coil legs of straight wire and tight turns at the ends
   Agree or Disagree?
    http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.html
Lorentz force and right hand rule | 1 comment (1 topical, 0 editorial)
Re: Lorentz force and right hand rule (3.00 / 0) (#1)
by bob g on Mon Sep 6th, 2004 at 08:50:58 PM MST
from what i have read i think you are right on this one,
seems as though output is directly related to the amount of wire that is cut by the magnetic field.
so it would stand to reason that square corners would allow more wire to be cut at the right angle.
bob g
  60 Scoop users have viewed this posting.
· http://hyperphysics.phy-astr.g su.edu/hbase/hframe.html
· Also by tecker
