| Way too much fun this weekend! I'm working on new machine.. maybe to be installed here, or maybe I'll save it to power the shop I'm hoping to build come spring time.
I spent yesterday cutting out metal parts. All the work was done with a bandsaw and a hole saw on the drill press. Of course.. it's a dual rotor machine. The rotors are 16" diameter, from half inch thick steel. There will be 16 magnets on each rotor, the magnets are 1.5" wide, 3" tall, and 3/4" thick. The stator will be 20" diameter, and 5/8" thick. Im hoping for about 2.5 - 3KW @ 200 rpm. I figure it'll be good for a 17' prop (give or take 1').... but that's just a guess untill I test a completed alternator.
The hub I got from a trailer supply store, it's much larger than a Volvo, although I'm allready wishing I'd gone with a larger one. I'm also wishing now that I'd gone with larger rotors. AT 16" diameter, the magnets will be fairly crowded on theire inner diameter so there will be some cancellation in the coils. It should work OK anyhow. The main reason I went with 16" is that it's the biggest diameter I can work with on my drill press should I need to work on the center. As it turned out though - it was much cheaper and easier to have this done and it would've been quite easy to have larger rotors made. The rotors were made at 'Colorado Iron and Metal' - they have a CNC water jet cutter. They came out really nicely... The rotors cost me about $75 ea (I had 4 made) - that included materials, setup, and the cost of cutting. They cut all the holes in the middle and everything came out to a very high tolerance.
The Yaw bearing is 3" pipe and it's 16" long(allready wishing I'd gone bigger! - but it's twice as big as my current 14' machine). The tail pivot is about 1.8" OD thick walled tubing, and it's attached to the yaw bearing with a bracket cut from 1/2" steel. The tail bearing will be from 2" diameter pipe.
That's about where I got at 11PM last night. I think the only reason I made it to bed at all last night was.... I ran out of diesel fuel! Sometimes I get into something like this and go til the wee hours. I suspect it'll move along quickly - hopefully in a week or so I'll have some prelimary information on the completed alternator. I've not decided yet if I should dare try to build a machine this big for 12 volts (thats what my system is now but I intend to upgrade someday). I think I could - if I widen the airgap, run a slightly smaller prop and have it furl early, but the temptation is to go straight for 48 volts with it. At 12 volts I think I'd be dealing with unreasonably thick wire. Im guessing that, for cutin between 60 and 70 rpm - I'll want about 15 - 20 turns per coil for the 12 volt machine. Lots of fun... most of the fun for me is in the building - who knows when I'll actually get this one up. |
254 Scoop users have viewed this posting.
