Board wierd behavior fix
By ADMIN, Section Site News
Posted on Mon Jan 17th, 2005 at 06:32:13 PM MST
Here's a bizarre, but effective fix if the board makes you log in over and over or gives 'permission denied'
I've traced this bug down to database tweaks we made to improve the board's performance, so it wouldn't slow to a crawl during heavy use (like when we get slashdotted).
Problem synopsis:
If you log in successfully, read a story (or try to post or comment, or anything), you hit "front page" or any section page again, and it makes you log in again or gives you "permission denied" if you are trying to post...it's losing your user permissions. Makes it hell to try and post. Then, the problem suddenly fixes itself.
From here, on 3 different browsers, if you log in and immediately click "User Preferences" that problem will fix itself and you won't have to keep logging in. I have no idea why, but I just made 3 new user accounts from here, all had the bug in them, and all fixed themselves after going to "user preferences".
Obviously this is a big bug--but at least for now this is a workaround. I've set new users to display User Prefs on first login, and am testing to see if that will at least help new users. We are getting a large volume of email from users because of this problem, and I am trying desparately to keep up with them and still do my job (this board is only supposed to be 10% of my workload, and it is at 99% right now ;~)
Still no luck on why comments don't appear if you are not logged in.
Any other user comments on these bugs appreciated, especially to see if this workaround fix works for you!
ADMIN
(that's Dan F, who is getting very grouchy and stressed about these problems)
Board wierd behavior fix | 16 comments (12 topical, 4 editorial)
Re: Board wierd behavior fix (3.00 / 0) (#5)
by baggo (baggo@copperstream.co.uk) on Mon Jan 17th, 2005 at 12:14:24 PM MST
(User Info) http://www.baggo.copperstream.co.uk
Hi Dan,
I've cured my own particular problem i.e. not being able to read comments unless logged in by changing the display setting from nested to flat. I've never noticed what it was originally set to so not sure if I might have accidentally changed it without realising. Works fine now though. Good luck with the other problems!
John
Re: Board wierd behavior fix (3.00 / 0) (#6)
by danbob88 on Mon Jan 17th, 2005 at 12:36:17 PM MST
We know about that one...it's #2 onthe list of stuff to fix :-(
ADMIN
Re: Board wierd behavior fix (3.00 / 0) (#7)
by danbob88 on Mon Jan 17th, 2005 at 12:39:57 PM MST
Huh, with this account it worked fine from the setup and did not cause the bug.
ADMIN
Re: Board wierd behavior fix (3.00 / 0) (#16)
by rpcancun (hobbyshopmx@hotmail.com) on Wed May 3rd, 2006 at 12:29:42 PM MST
It seems there are now 2 RP's on this system.....can it be fixed??
Re: Salvaging Magnet Wire from Large Motors (3.00 / 0) (#11)
by RP (russp located-at fidnet (dot) com) on Tue May 2nd, 2006 at 07:57:44 PM MST
Thats not me....
Re: Board wierd behavior fix (3.00 / 0) (#8)
by nothing to lose (nothingtolose175 at yahoo.com) on Mon Jan 17th, 2005 at 02:01:55 PM MST
I don't think I have had the problem that was mentioned here (so far) but a few minutes ago I tried to post a message and I would just get an apache error port 80 type message, alittle text on a blank screen. Clicking back a few times got me to the front page again but would not let me into the messages I clicked to read, just sat dead.
Haven't done anything else and now I try it and if this message DOES post then for now it works again here.
That was using fire fox.
Also I tried EI and just got a Fedora Core test page
"This page is used to test the proper operation of the Apache HTTP server after it has been installed. If you can read this page, it means that the Apache HTTP server installed at this site is working properly.
If you are a member of the general public:
The fact that you are seeing this page indicates that the website you just visited is either experiencing problems, or is undergoing routine maintenance."
Huh maybe it was down and you were working on it :)
Thought I'd mention it anyway just in case it shouldn't have been.
Also I have been having alot of problems myself recently (week or more) that clicking a link just doesn't do anything. Little Icon lights in the task bar flash once or twice when I click to read or reply or post a message, then they stop and nothing happens. Sometimes after about the 3rd or 4rth time I get the page/link to work.  Hadn't mentioned it before since I thought it could be my side having a problem. Either Firefox or with my dialup, but other sites do not seem to be having that problem, or at least not nearly as bad since I haven't noticed them.
 When that happens I don't get any errors, just nothing ever happens, just like not clicking anything at all.
Good luck, Love the board, hope you can fix it!
Re: Board wierd behavior fix (3.00 / 0) (#9)
by hiker (hiker.wild[at]yahoo[dot]com) on Mon Jan 17th, 2005 at 02:30:16 PM MST
works fine 4 me.................
mozilla....
WILD IN ALASKA
Re: Board wierd behavior fix (3.00 / 0) (#10)
by pyrocasto (pyrocasto at hotmail dot com) on Mon Jan 17th, 2005 at 05:20:17 PM MST
Only thing I cant figure out is I will post something, then I go back and check and it didnt post. So I have to write it over again.
Re: Board wierd behavior fix (3.00 / 0) (#11)
by Epower (EpowerPlus@hotmail.com) on Mon Jan 17th, 2005 at 06:44:20 PM MST
This is not in my field, but The problem started on th 15th or 16th. All recent post are having this problem but not the older post. All surfers outside of this membership will encounter this problem. To me there is a link missing to the comments section. I hope this helps...Epower
Re: Board wierd behavior fix (3.00 / 0) (#12)
by ibedonc on Mon Jan 17th, 2005 at 08:01:54 PM MST
seeing if it works for me
Re: Board wierd behavior fix (3.00 / 0) (#13)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Mon Jan 17th, 2005 at 11:17:57 PM MST
 The only weird thing that's happining to me is ,  sometimes the pictures don't load, just the text shows with little broken picture boxes wher all the pictures should be. If I right-click and choose 'View Image' I get a green screen that says the picture is not on Otherpower.com
The other problem is with the WonderMagnet site. Every page on the WonderMagnet site has a link to This Discussion Board, The mainpage has several links to this board.
But ALL those links are Broken. It says something about not able to find magnets.
)}=- W o o f -={(
Re: Board wierd behavior fix (3.00 / 0) (#14)
by PaulJ on Tue Jan 18th, 2005 at 04:50:37 AM MST
   I hate adding to your problems, but recent comments I've already read are still showing up with the red [new] tag, even if I log out and in again.
   Postings seem ok, they don't show up new once I've read them.
   Is anybody else experiencing this?
   Good luck + don't get too stressed!
   Paul
Re: Board wierd behavior fix (3.00 / 0) (#15)
by Ungrounded Lightning Rod on Tue Jan 18th, 2005 at 08:13:07 PM MST
I was seeing that too (under Mozilla 1.5).  Hit preferences, saved them unchanged, then went back and reloaded the front page.  All fixed.
Perhaps all these troubles have a single cause.
  134 Scoop users have viewed this posting.
· Slashdot
· Also by ADMIN
