| Hi all!
This is my first diary entry. Ive posted lots of small, unconsequential toys in the past but this is the real deal.
I cant go too far into specifics just yet because i might actually market this idea. It is a very sweet package.
Basically, as is i have 65w @ 12v / (by ohms law) 5.41 amps (by manufactuers ratings) 4.85 amps
First can someone explain the discrepency in amps? (15w + 50w)
Now, I can expand the amount of panels on the array in the future but what im worried about is buying batteries.
By the numbers i understand 5A is good to charge @ 4.5A after losses. I dont want to go further then 20% on the batteries, so is 4 x 4.5A (http://www.batterymart.com/battery.mv?p=SLA-12V4D or similar) the right idea?
This setup will allow for 18AH per day (4x5-lo%s) charging power to my pack. This will give me about 2.8(ish)A per hour reliably and keep my batteries in the 20% discharge range?
My real question starts here. The above figulation was done assuming there will alwas be a load to discharge to. Of course i have a charge controller but should i consider 2 more batteries for extended periods of charging without use?
My second question is, I think i can fit about 200w total on the array. Im scared to buy these small batteries because at 200w the numbers change. So would these batteries have to go for sale at that point or could i efficiently add more 4.5AH batteries as i expand? This is a real killer for me. Im sooo close but i hate jumping onto loose stones ;)
126 Scoop users have viewed this posting.
