| In preparation to install my new wind turbine, I'm working towards changing my system over from 12 Volts to 48. I was pleased to find that pretty good savings can be had by purchasing 'refurbished' Trace inverters. I expect that selling my old SW2512 will cover most of the cost of my new SW 4048 which is nice. The other main expense for now will be batteries, I need 2 more L16's.
The tricky part is the solar panels. Right now I've got 7 'Solarex' 65 watt panels on my 'front' array. They are 12 volt panels, so I figure 4 of those will make a nice string for 48 Volts, but the problem is... I cannot find the very same panel for sale anymore which leaves me with 3 'strays'. The closest I found is a BP solar 65 watt panel, it's almost exactly the same size and looks very similar, so I've ordered one of those - I believe that will solve all the issues with my 'front' solar array.
The biggest problem is my 'back' array. There I have a 'Matrix' 105 watt panel, which can be wired for 12, or 24 Volts. This panel is no longer manufactured - and even if it were, I cannot really afford another panel at this time. I also have 2 old carrizo 'quads' (ugly old browned panels in wooden frames that produce about half of what they ought to for their size). Each 'quad' makes for a 12 volt panel - and between the two I currently get about 6 - 8 Amps into the batteries. My current thought - is wire up the Matrix panel to produce 24 volts, and then wire the 'quads' in series for 24 volts, and put the whole lot in series to make a 48 volt array. Surely it's not an ideal setup... but would there be any harm in giving it a shot? It seems like all the quads together produce similar power to the Matrix panel, so my thinking is it might not be a bad match. |
126 Scoop users have viewed this posting.
