I started with a 1 lb coffee can and poured in about 1" of used motor oil, then threw in some fiberglass insulation that I rolled into a ball, about the size of a tennis ball. I stired it around in the oil until it was saturated. This pretty much soaked up all the oil and things looked alot more like an oily paste than a ball of fiberglass in oil. I poured about a table spoon of terpentien (sp) on top of the ball of fiberglass and lit it. It lit well and smoked pretty good. I found a length of chainlink fence post and held it down into the coffee can and pretty quickly the flame/smoke got a 'draft' going and began 'sucking' the flame up the tube. This must have got things burning more effeciently because the smoke went away and there was a sound comming out of the tubing like a jet engine. Someone standing 30 feet away would have heard it faintly. I help the tubing over the tincan a number of times, until the thing got too hot to hold. This little bit of oil burned for 3 hours. I then cut a hole in the side of another coffee can about the size of a quarter. This was done so the bottom of the hole was some 2" from the bottom of the can. I poured in oil till it was ready to run out the hole, then added another ball of fiberglass. This time the tube was mounted to sheetmetal that covered the top of the cofee can. I poured in a few drops of turpintine and lit it through the hole in the side of the can. The stove Really heated up and the first 6" of the tube got red. I'm sure the hole should have been larger, as there was quite a bit of smoke coming from the stack and the flame would 'puff' out the hole quite a bit. The results are in: Next time I mess with it I'll cut a larger hole for the air inlet and will use a larger container, like a 20 lb. freon bottle. I'm thinking I can put 2 quarts of oil in and give it the 'long term test. My oxy/ace tanks are going to be refilled tomorrow so I can weld up the smoke stack 'right' I'll get this all set up and lite it early on the weekend and see how long it burns. This was a real fun project.
160 Scoop users have viewed this posting.
