Circuit schematics
By BT Humble, Section Controls
Posted on Sun Jan 30, 2005 at 11:22:58 PM MST
Found a site, liked it, thought I'd share
I was googling for a couple of sample schematics (namely a car headlight reminder and a temperature-controlled fan driver), and found them here:
http://www.uoguelph.ca/~antoon/circ/circuits.htm
There seems to be a very wide selection of useful stuff for those of us who are interested in building their own gear (I hear one or two people around here are like that?) ;-)
BTH
Circuit schematics | 7 comments (7 topical)
Re: Circuit schematics (3.00 / 0) (#1)
by picmacmillan on Sun Jan 30, 2005 at 05:10:49 PM MST
now thats a good site for a guy like me who needs to know alot of stuff.....thanks....pickster
Re: Circuit schematics (3.00 / 0) (#2)
by eureka on Sun Jan 30, 2005 at 07:43:32 PM MST
Some of my favourites
http://www.discovercircuits.com/index.htm
http://www.epanorama.net/index.php
http://www.mitedu.freeserve.co.uk/Circuits/cctindex.html
Re: Circuit schematics (3.00 / 0) (#3)
by richhagen on Mon Jan 31, 2005 at 01:07:05 AM MST
I built a hv supply based on the dazer circuit on that site a while back.  Put it in a battery powered skeeter killer.  It's got a great variety of circuits.  Rich Hagen
a circuit for a dump load? (3.00 / 0) (#4)
by hvirtane on Thu Feb 03, 2005 at 05:47:56 AM MST
Anyone knows an easy circuit for
a dump load for a wind generator
about 1 kW maximum?
Re: a circuit for a dump load? (3.00 / 0) (#5)
by BT Humble on Sun Feb 06, 2005 at 02:52:43 PM MST
Are you looking for a shunt regulator?  What is the system voltage?
BTH
Re: a circuit for a dump load? (3.00 / 0) (#6)
by hvirtane on Thu Feb 10, 2005 at 05:29:56 AM MST
Yes, I'm looking for a shunt regulator.
We needed as well a good circuit to prevent
discharging batteries too low.
At present
we are using 12 Volt systems, but in the
future also 48 volt systems and then we
would need also need big shunt regulators
up to 10 kW.
Have you or anybody else (besides Hugh himself) used the circuit as described by Hugh here:
http://www.scoraigwind.com/circuits/chargecontrol.htm
How big currents can it take in?
Re: a circuit for a dump load? (3.00 / 0) (#7)
by BT Humble on Mon Feb 14, 2005 at 02:31:23 PM MST
I couldn't say, Hannu.  I haven't actually built a regulator yet, but I think you should be able to make them as big as you like simply by connecting a big enough relay across the "shunt" connections of any circuit.  You'd want to put a diode "backwards" across the relay's coil to prevent any back EMF from harming the electronics though.
BTH
  156 Scoop users have viewed this posting.
· http://www .uoguelph.ca/~antoon/circ/circuits.htm
· Also by BT Humble
