4KW Wind Generator For Sale
By mmm, Section Classifieds
Posted on Mon Jan 31st, 2005 at 07:19:11 PM MST
4KW Whirlwind For Sale
1986 Model 4KW Whirlwind. 16' Blade, 120Vdc 3 phase, 70' Guyed lattice galvinized tower. I have the complete control box also have a 12kw 120vdc Best M series Inverter 120/240 AC and a 240volt to 120 volt DC battery charger, plus a spool of wire to run to the tower and most of the guys and turnbuckles. BEST OFFER
Russ, Colorado
triplemconstruction@msn.com
4KW Wind Generator For Sale | 11 comments (11 topical, 0 editorial)
Re: 4KW Wind Generator For Sale (3.00 / 0) (#1)
by TomW on Mon Jan 31st, 2005 at 12:38:20 PM MST
Russ;
hmm, my first question is how much did you mess with it from advice from this story:
http://www.fieldlines.com/story/2004/12/27/211357/67
T
Re: 4KW Wind Generator For Sale (3.00 / 0) (#3)
by mmm on Mon Jan 31st, 2005 at 02:53:02 PM MST
I havent tore anything up on it. Just opened the wires where the three phases hook up but some varnish will seal them back up.
Re: 4KW Wind Generator For Sale (3.00 / 0) (#2)
by juiced on Mon Jan 31st, 2005 at 02:27:58 PM MST
(User Info) http://www.juiced.ca
Is the machine in Canada?
Canada's -Debatable- A.E./R.E Debate Site
News, discussions and debates!
www.juiced.ca
Re: 4KW Wind Generator For Sale (3.00 / 0) (#4)
by ghurd on Mon Jan 31st, 2005 at 04:05:03 PM MST
Colorado.
Re: 4KW Wind Generator For Sale (3.00 / 0) (#5)
by johnlm on Mon Jan 31st, 2005 at 08:29:35 PM MST
How much does it weigh?  How about a picture or two?
Re: 4KW Wind Generator For Sale (3.00 / 0) (#6)
by Chuck on Mon Jan 31st, 2005 at 08:33:14 PM MST
(User Info) http://home.morrisonprairie.com
Hi Russ,
Where in Colorado? If you're in the Northern Front Range area I (and a few others I'm sure) would like to come take a look.
Chuck
Re: 4KW Wind Generator For Sale (3.00 / 0) (#9)
by mmm on Tue Feb 1st, 2005 at 08:10:56 AM MST
I live outside of Canon City which is about an hour west of colorado springs. I will try to get some photos posted today.
Re: 4KW Wind Generator For Sale (3.00 / 0) (#7)
by Nando (nando37-at-tx-dot-rr-dot-com Correct theanti-spam) on Tue Feb 1st, 2005 at 07:09:20 AM MST
This systems needs a 120 volts battery bank and it would be an excellent system if working well.
Wind mill and a 12 KW 120 Vdc to AC converter plus a AC charger for the 120 volts bank
Question is: Have the system been operated at all or you were not able to install it ?.
I have, always, promulgated the fact of using the highest possible voltage, for the greatest efficiency and easiest maintenance, easy power transmission etc.
I have installed systems with 400 volts battery banks with parallel converters for uninterrupted AC power generation.
4 KW wind mill may give around 20 KWH a day with just a few hours of wind availability.
Source that may be good for several households.
Regards
Nando
Re: 4KW Wind Generator For Sale (3.00 / 0) (#8)
by Nando (nando37-at-tx-dot-rr-dot-com Correct theanti-spam) on Tue Feb 1st, 2005 at 07:16:13 AM MST
Russ:
I went to see the link in one of the responses.
It seems that you are not able to determine the capabilities of the wind mill, but with what you are offering if everything works that is a great system that just needs a battery bank of 120 volts to produce a great amount of power.
There are simple tests for the windings checking and polarity --
If you want connect directly to see what can be done with your system
Regards
Nando
Re: 4KW Wind Generator For Sale (3.00 / 0) (#10)
by jemetos on Tue Feb 1st, 2005 at 11:18:53 AM MST
Hi
you might like to post a free advert on my energy focused website. We get lots of visitors form around the world including ebay. It's free. easy to use and quite like ebay - but it's free! and its only for energy products like wind turbines, solar, etc. plus some other areas that my users seem to like.
the adrress is www.wxtrade.com
Re: 4KW Wind Generator For Sale (3.00 / 0) (#11)
by mmm on Tue Feb 1st, 2005 at 01:43:04 PM MST
Here are some photos
This is the control box with DC disconnect fuses and generator brake
This is the 240 volt charger
This is the blade there is a little damage on the trailing edge but is repairable
And no the boat doesnt go with it.
This is 40 ft of the tower cables and the other thirty feet is not shown
And the 4kw PM 3 phase generator. I also have new bushings and furling stops that I puchase from kansas windpower
  216 Scoop users have viewed this posting.
· Also by mmm
