I got a JD165 3.3 diesel engine off Ebay $200.
Mounted it to a 2' dia x 1' hardwood log.
Added a G3 motorcraft 130 amp alternator to it. (belt driven 2 v belts) 1:1 ratio.
Added a diode to the sense wire off regulator to force output voltage to 14.6 cold and 14.1 hot.
Removed hopper tank and added a top plate with 3/4 nipple. Removed drain cock and installed a 1/4 nipple. Added a pump and circulate water in the botton and out the top of the engine. Water pumps from a barrel 16 gallons through the engine and back to the barrel. Added a thermometer to the barrel of water.
Test run. Engine shakes like crazy. Had to mount it to something heavy.
Engine noisy as heck. Can't run open in the neiborhood. I made an enclousure out of concrete wall board... lowes,$30.00 did the trick.
Ran 1 gallon of diesel fuel over 2 weeks on 1 -3 hour runs.
Loaded the alternator from 20 amps to full 60 amps and back. Ran mostly 20 amps. Engine rpm was from 1000 - 2000.. Mostly 1500 rpm.
Engine feels broke in now. Super eazy to turn flywheel by hand.
Engine uses 16 oz of diesel per hour on light load at 1200 rpm. Book says 300 g/hw.h at 1200 rpm.
Engine produces 5000 + btu of heat an hour at heated water.
Engine will take 16 gallons of water from 65 degreessF to 120 degreesf in 1 hour.
This project is for 24/7 winter backup heat/power for off times. A gas 3 kw 25 amp@120 volts is for demand loads 2-4 hours a day.
More later.
David |
110 Scoop users have viewed this posting.
