| I've been wondering about tying the "Common" wire to Ground as most existing houses (and grids) are wired. (Currently I am working off grid).
With a cheap 12V - 110V inverter, the first inverter that I had (300W) whined and complained when I had tied the White Common wire to ground. The second inverter (700W) blew out almost immediately doing this (ok, so I've been experimenting a bit).
I've partially gotten around the issue by putting in a 110/220V transformer... bumping up my power to 220V, and then splitting out the two 110 circuits. However, the problem is now that I have to be quite symetrical in my usage. If I turn on a single 10W bulb... it won't work. I have to turn on two 10W bulbs (separate halves of the circuit) to get it to all work.
I may be going to Compact Fluorescent DC Lighting so this may not be as big of an issue as I had thought.....
How are other people dealing with this?
Is this one of the advantages of a $3000 inverter over a $30 inveter? Sinewave might be nice, but if modified sine runs most of my stuff, it may be ok, and I believe that it has a much simpler circuit and less overhead. |
102 Scoop users have viewed this posting.
