up untill now, all my experiments have been with ceramic mags.(free, and easy to manipulate).i feel i'm begining to understand(thanks to this discusion board) how the various components work together to produce current.
in responce to mr.koos post, i began visiting local computor repair shops. broken hardrives are free and the stores are only too happy to be rid of them.
in order to best utilize the 60 little neos i have collected i have questions:
1/ is it necessary to cut them up? using them as is , with two poles per mag would produce a current but my instinct is that it would be half of what could be harvested if the mags were cut and flipped to form a single pole each. ive searched the archives and found only a coil layout diagram but there was no output figures.
the mag spacing / coil shape did not appear very efficient the leg lengh coil width ratio looked wrong .
2 hiker has posted a project where he used hd neos to resurface ceramic mag rotors and increased the power output. this is tempting. but a have observed that there is less effort required to move(slide) a hd neo placed on a pole of a ceramic mag rotor than over a bare steel rotor( that is surprising to me) .with out a gauss meter i am curious as to wether there is more available flux from the hd neo by itself or from a hd neo with a 1/2 " ceramic beneath it?
standing here in my raincoat with wet tile saw, awaiting any replies.
thanks, shawn |
100 Scoop users have viewed this posting.
