| G'day,
The other day I've found an old gas-tank (LPG, not gasoline) of 100l (26 gallon). My immediate thought was 'batch heater!'. Actually, I've held the saw to start working on it. (no worries, it'll be flushed out twice with water to make sure no more gas is inside; I don't want this to be my last project)
However, I'm wondering: the tank is plain steel (it's quite rusted on the outside, but only superficial). Will rust (on the inside) be an issue? I initially assumed it wouldn't (since no air will be inside), but on the opposite side: there's water, it's hot (up to 80 deg.C?) and there's dissolved oxygen in the water...
I also have a 25 l tank (8gallon) from an old air compressor, but I think it's too small and it's plain steel too...
If I had other/better containers I'd use those, but alas.
So, has anyone else made batch-heaters out of these kind of tanks? Did you experience excessive rusting?
Other question: did you use special black paint (to withstand high temperatures), or plain paint; does this hold up well?
Looking forward to your opinions,
Peter,
The Netherlands. |
