Wind sock duct work
By hobot, Section Wind
Posted on Sat Dec 17, 2005 at 01:32:24 AM MST
Concentrating wind idea
Biggest issue I've seen in ducted turbines is for about same
material and efforts you could have two or more turbines.
Having sat in a sail to be flapped up and around as if mere twig...
I've been picturing a sail boat like spinacker with a fan in
a vent hole. Many issuses to support and wind face such a rig, solid
or air inflated stiffening to hold a a box fan like mill.
Anywho this is closest I could find online so far, see what you
think or add to for fun or power.
http://www.eng-tips.com/viewthread.cfm?qid=64614&page=1
Wind sock duct work | 5 comments (5 topical)
Re: Wind sock duct work (3.00 / 0) (#1)
by MountainMan on Fri Dec 16, 2005 at 07:59:12 PM MST
hobot,
It is indeed an interesting topic, and has been addressed a few times here even in the last month or so (the basic idea of "funneling", that is).
One poster of late suggested that dealing with the "fluid dynamics" aspects of the problem make an exponential entryway more appropriate.  He also stated that having a similar exit baffle that gradually widens in an exponential way would be another improvement.  I find that last part counter-intuitive but believable and worthy of some experimentation.
I have several ideas for ways to couple the strong East/West directionality of the wind in my area with a desire to avoid using a tower and my plans to be off-grid, and so need to make power even with a 5mph wind on the calmest of days here.  I think that clever use of baffles and "funnels" can make it possible to largely "hide" a wind turbine and still get lots of juice from it.
Time will tell.  The experimentation will be even more fun than the armchair theorticizing (sp).
jp
MountainMan, Julian California
http://www.real-home-based-business-opportunity.com
My ultimate hobby project is to build a ten foot tall robot.
Re: Wind sock duct work (3.00 / 0) (#3)
by sahlein on Sun Dec 18, 2005 at 05:33:07 PM MST
You know, this is not as "hokey" as it may seem on the surface.
There are several places in San Francisco that are virtual "wind tunnels"!
One place is only one block long but I've measured 7mph there when there is only a noticeable breeze elsewhere!
Sahlein
Re: Wind sock duct work (3.00 / 0) (#2)
by hobot on Fri Dec 16, 2005 at 08:42:46 PM MST
Hey Mt. Man,
I'm learning, but only from my rocking chair so far.
There are some VWAT that are inside a big cylinder with slots/vanes
that grab wind to the center no matter which direction it hits,
kinda like a squirrel cage blower on its side. Again materal/effort
vs just making another plane jane arises. Maybe if sail sheets could
be hung to collect a wall of wind from any direction to a center
turbine might merit thot in some sites.  Darn it the wind moves so
much mass just in light breezes of leaves and topples em in busts
there's pony power in teasing evidence.
Looking into pulse jet rocket ventri concepts is really fun
some have a reversed trumphet looking desigsn to add thrust forward.
http://www.google.com/custom?q=valveless+pulse+jet+designs&sa=Search&client=pub-637996212490
  1. &forid=1&ie=ISO-8859-1&oe=ISO-8859-1&cof=GALT%3A%23008000%3BGL%3A1%3BDIV%3A%2333
  2. %3BVLC%3A663399%3BAH%3Acenter%3BBGC%3AFFFFFF%3BLBGC%3A336699%3BALC%3A0000FF%3BLC%3A0000FF%3BT%3A
  3. %3BGFNT%3A0000FF%3BGIMP%3A0000FF%3BFORID%3A1%3B&hl=en
But it made me think that on a Vertical axis instead of just shelding
on rushing blades why not extend sheild into a scoop that redirects
air flow behind the returning blades. Least it might do is relieve
the low pressure behind the blades and at best add some ummph, noting
that it would be dumping out into the non sheilded trade wind flow
that's expected to do the lions shade of turning torque. But I don't
know if that's good or not, may just make it stall faster : (
I guess a spinaker could be set on a large dia swivel base. My picture
of it is to use a jet compressor looking multi short blade turbine
with a large dia center streamline hub to squeeze the pressure built
up into velocity. Thot maybe a truck inner tube to hold the port rigid
and act as part of venturi to a rather large patch of lower pressure
on far side of sail wind shadow. Would bright spiacker in wind be thot
of as unsightly? Would birds be attracted and sucked in ...
hobot
Re: Wind sock duct work (3.00 / 0) (#4)
by IntegEner on Mon Dec 19, 2005 at 07:08:15 PM MST
Buildings make great wind concentrators especially the peaked roofs. It has always seemed like wind energy is missing the boat in not having available something that can be put inside a cupola mounted on the roof of a garage or shed. The turbine can be hidden behind slats without much loss and the power goes to charge the batteries of the hybrid car parked inside or to drive the house ground source heat pump, all DC, of course. It would catch the public's fancy. It is when wind energy gets into grid tie where ordinary homeowners in suburbia find other alternatives.
Anthony Chessick
www.integener.com
Re: Wind sock duct work (3.00 / 0) (#5)
by Kwazai on Tue Dec 20, 2005 at 06:23:37 AM MST
I have not been back to this to try some other things yet but at only about 10ft. tall it doesn't have enough airflow to make it move. sometime in the future maybe (parafoil turbine...)
L8r
Mike
http://www.fieldlines.com/story/2005/2/9/154432/0686
  112 Scoop users have viewed this posting.
· http://www .eng-tips.com/viewthread.cfm?qid=64614&page=1
· Also by hobot
