i just found some rigid foam insulation made by Dow Chemical .
it is called polyisocyanurate insulation..
it is pretty stiff and cuts like butter..
if i coat the outside with fiberglass for strength will this work as a set of blades?i am thinking of using the whole width ( four feet ) for the radius of a three blade set.
it comes in sheets about four feet wide x eight feet long by an inch thick . i think this will make an excellent formable blade.
i am thinking of laminating it , to make it thicker ?
i found a whole sheet of this stuff so i have a lot to play with |
162 Scoop users have viewed this posting.
