| Hi all, I've been lurking a while and reading over old posts. I'm stuck with a problem and hoping that you knowledgeable types will be able to advise me.
I'm trying to build a very small Giromill (< 3ft) mainly for fun but also to provide a few watts for lighting in the garage.
I've built a 2 bladed model with NACA 0015 airfoil section blades 150mm wide and about the same height mounted on a dual rotor arms 500mm diameter. The blades are free swivelling attached at the front and so far tried two configurations :-
- Fixed blades with 0 degree pitch angle i.e. perpendicular to the rotor arms and this completely failed to start in all winds upto 20mph so not a great deal of use.
- Free swivelling blades with stops at 0 degrees and also -90 degrees i.e. pointing outwards parallel to rotor arms, this starts readily even in light winds but only ever operates in drag mode i.e. one blade offering maximum resistance to the wind and one offering minimum. Another problem with this design was the terrible clattering impact forces of the blade banging against the stops which cause vibration and eventually broke the stop.
I'm trying to come up with a simple mechanism that allows the model to self start in low winds and then quickly acheive the hypersonic TSR > 3 in lift mode. I saw the photo's on Ed's website of his cycloturbine type design which looks complicated and I don't understand how it works but there must be simpler methods.
BTW Ed's suggestion was to use his Lenz design which is my fallback plan.
Andrew
177 Scoop users have viewed this posting.
