STATIONS FOR BLADE WITH DIAMETER 5 METERS
By steeolico, Section Wind
Posted on Fri Dec 02, 2005 at 07:24:58 PM MST
I would like to build some blade in wood for a jenny of 5 meters with tsr 6, you can point out me the measures and the design of the sections.
Thanks (translation software)
STATIONS FOR BLADE WITH DIAMETER 5 METERS | 15 comments (15 topical)
Re: STATIONS FOR BLADE WITH DIAMETER 5 METERS (3.00 / 0) (#1)
by Nando on Fri Dec 02, 2005 at 12:30:12 PM MST
Interesting indeed.
Have you defined the generator, the charge controller and the use of the energy ?.
Heating or electrical power ?.
What type of RPM control? Pitch Control or Furling ?.
Nando
Re: STATIONS FOR BLADE WITH DIAMETER 5 METERS (3.00 / 0) (#2)
by steeolico on Fri Dec 02, 2005 at 12:41:38 PM MST
yes, 16 magnets 46X60X10 mm., coils 12 for 26 turns double wires 2,35 mm., 3 phase, 24v sistem, cut-in 90 rpm.
steeolico
SECTIONS FOR BLADE WITH DIAMETER 5 METERS? (3.00 / 0) (#3)
by steeolico on Fri Dec 02, 2005 at 12:45:39 PM MST
I would like to build some blade in wood for a jenny of 5 meters with tsr 6, you can point out me the measures and the design of the sections?
Re: SECTIONS FOR BLADE WITH DIAMETER 5 METERS? (3.00 / 0) (#5)
by Nando on Fri Dec 02, 2005 at 01:50:07 PM MST
How much power are you expecting to harvest at what Wind velocity and RPM.
Nando
Re: SECTIONS FOR BLADE WITH DIAMETER 5 METERS? (3.00 / 0) (#11)
by steeolico on Sun Dec 04, 2005 at 10:27:34 AM MST
I think about finding a power of around 3500-4000 Ws to 200-220 rpms, with a cut-in of 4m/s to 90 rpms.
At least I hope both so: -)
Re: SECTIONS FOR BLADE WITH DIAMETER 5 METERS? (3.00 / 0) (#6)
by ivandenisovich on Fri Dec 02, 2005 at 03:23:23 PM MST
Lets see if I can get the columns to line up
    radius    angle b    angle b    Chord    blade width    blade width    drop    thick
Station    rad.    radians    degrees    C    recommend    used W (M)    Dr (CM)    T (M)
  1.     0.12    1.078    61.8    0.546    0.258            0.260           .481    0.095
  2.     0.25    0.768    44.0    0.725    0.521            0.260           .504    0.047
  3.     0.37    0.568    32.5    0.697    0.588            0.588           .375    0.139
  4.     0.50    0.437    25.1    0.619    0.561            0.561           .262    0.116
  5.     0.62    0.348    20.0    0.541    0.509            0.509           .185    0.097
  6.     0.75    0.285    16.3    0.475    0.456            0.456           .133    0.083
  7.     0.87    0.238    13.6    0.420    0.409            0.409           .099    0.072
  8.     1.00    0.201    11.5    0.376    0.368            0.368           .075    0.063
  9.     1.12    0.172    9.9    0.339    0.334            0.334           .058    0.057
  10.     1.25    0.149    8.5    0.309    0.305            0.305           .046    0.051
  11.     1.37    0.130    7.4    0.283    0.281            0.281           .037    0.046
  12.     1.50    0.113    6.5    0.261    0.259            0.259           .030    0.042
  13.     1.62    0.099    5.7    0.242    0.241            0.241           .024    0.039
  14.     1.75    0.088    5.0    0.226    0.225            0.225           .020    0.036
  15.     1.87    0.077    4.4    0.211    0.211            0.211           .016    0.034
  16.     2.00    0.068    3.9    0.199    0.198            0.198           .014    0.032
  17.     2.12    0.060    3.4    0.187    0.187            0.187           .011    0.030
  18.     2.25    0.053    3.0    0.177    0.177            0.177           .009    0.028
  19.     2.37    0.047    2.7    0.168    0.168            0.168           .008    0.027
  20.     2.50    0.041    2.3    0.160    0.160            0.160           .007    0.025
Tip speed ratio            TSR    6
Diameter (m)            D    5.00
number of blades        Bl    3
angle of attack a (deg)    AT    4
Lift coefficient    Cl    0.8
#stations            STN    20
One comment, with a TSR of 6, your cut in wind speed will be about 4 M/S, which is a little high.  You could cut in a little lower, say at 70 RPM (or 3 M/S) if you increase your coil turns to 35 or so.  I don't think you are going to get everything you can out of a 5 meter rotor with so few turns.
Paul, I'd rather spend my money on anything but oil.
Re: SECTIONS FOR BLADE WITH DIAMETER 5 METERS? (3.00 / 0) (#14)
by steeolico on Sun Dec 04, 2005 at 10:42:04 AM MST
I will perhaps increase the turnses in 32-35 of the coilses, to have a cut-in lower, my fear is that so can brake the turbine to taller winds.
It will still spend a lot of time before I succeed in realizing the jenny from 5 ms.... but with calm, in the leisure time, I will make one piece at a time....
Thanks for your suggestions they are very useful!
Stephen - Italy (translation software)
Re: STATIONS FOR BLADE WITH DIAMETER 5 METERS (3.00 / 0) (#4)
by antonio on Fri Dec 02, 2005 at 01:18:27 PM MST
The answer to your question is into spreadsheet:
http://www.scoraigwind.com/sheets/bladedesign.xls
Good luck
Antonio - Italy
Re: STATIONS FOR BLADE WITH DIAMETER 5 METERS (3.00 / 0) (#12)
by steeolico on Sun Dec 04, 2005 at 10:29:40 AM MST
Sei sempre un grande!!!
Re: STATIONS FOR BLADE WITH DIAMETER 5 METERS (3.00 / 0) (#7)
by zubbly on Fri Dec 02, 2005 at 03:45:47 PM MST
hello Steeolico!
here is a site that i have found very good
http://www.alton-moore.net/wind_calculations.html
good luck!
zubbly
Re: STATIONS FOR BLADE WITH DIAMETER 5 METERS (3.00 / 0) (#8)
by jmk on Fri Dec 02, 2005 at 07:12:14 PM MST
  I am just curious if you have your 12' turbine up yet? {3.5 meters?} If you do have it up does it make very much noise? I am building the same turbine and am concerned with the nois it will make. Are you flying all these at your place? You should be cranking alot of power. Do you have any good wind readings? I liked the pictures in your last post. If you have any more I would like to see them. Five meters, boy you are getting into the big ones now. Good luck, and have lots of fun. Keep us posted. I like to see the great pictures of the wind turbines everyone makes! This is the first year for me with a computer. I never knew what I was missing. Plus now since I have had it I bought a wood boiler, and I am now building a wind turbine. Thanks to all the help from this web site!
jmk
Re: STATIONS FOR BLADE WITH DIAMETER 5 METERS (3.00 / 0) (#9)
by RP on Sat Dec 03, 2005 at 05:57:17 PM MST
"I like to see the great pictures of the wind turbines everyone makes!"
http://images.google.com/images?svnum=10&hl=en&lr=&safe=off&q=site%3Aotherpower.com& amp;btnG=Search
Re: STATIONS FOR BLADE WITH DIAMETER 5 METERS (3.00 / 0) (#15)
by jmk on Mon Dec 05, 2005 at 05:29:55 PM MST
 Wow! Now that's alot of pictures. This would make a great screen saver.
jmk
Re: STATIONS FOR BLADE WITH DIAMETER 5 METERS (3.00 / 0) (#10)
by steeolico on Sun Dec 04, 2005 at 10:21:02 AM MST
My 3,6 meters turbine is not completed solmente the steel disks yet they miss me but will still want us time to lift her/it.
Today I have lifted the 2° jenny from 500W 2,4 meters however it is initiated to rain cats and dogs and I have not been able to photograph the cars.
I hardly succeed in the next days I publish the photos that I will do on the forum.
I think that you will lift before me your jenny of 3,6 meters, make to know me how it also works me I am very curious.
I also thank me all of you for the help that give me
Stephen (translation software)
Re: STATIONS FOR BLADE WITH DIAMETER 5 METERS (3.00 / 0) (#13)
by steeolico on Sun Dec 04, 2005 at 10:35:07 AM MST
Thanks a lot of for the help that give me, shortly I will publish other photos of new jenny!
Stefano - Italy
  144 Scoop users have viewed this posting.
· Also by steeolico
