| I am now convinced that I will be better off running a small generator to dump into my battery bank and using a large inverter rather than running AC directly off of the generator...
Thus, if I use a "Chop Saw", for example, it may only use peak power for a matter of seconds which I should be able to pull out of my batteries. There would be no reason to have a 110V - 2KW generator running for a few hours to cover these short few second surges when a battery is made to do it.
Yes, I know that using a generator is cheating a bit, but my solar array isn't quite keeping up with my demand.
Anyway, so I've purchased a HONDA EX350 Generator along with a spare Stator Assembly. The Stator assembly is a bit oily... perhaps from a blown engine. Hopefully the Stator itself is ok.
According to the wiring diagram (free download from Honda), the DC section of the motor is running in star pattern.
Inspecting the stator...
the first 6 coils are wired together, and must be DC part of the generator.
the next 15 coils are wired together for the AC portion of the generator.
Total of 21 alternator coils plus 2 magneto coils (I think).
Note, the magnets each have dual polarity with a N pole at one end, and a S pole at the other end, giving the motor 3 phase output.
I am planning on separating the sets of coils and rewiring to give myself an All DC generator (going to my own rectifier).
I have to decide if I want to wire the alternator into 3 banks of 6 coils (3 phase-star). This will leave me 3 unused coils... what do I do with those?
The other option would be to wire it in 7 banks of 3 coils (3 phase-Delta configuration).
Assuming that I could get enough power out of the Delta config, I should be able to optimize the coils, and to use all of the coils..
Hmmm, further inspection shows that the short coil that I have circled as Magneto actually is marked as "SW" on the wiring diagram and goes to the inverter.
The Tall - fat coil (EXW) is part of the ignition system.
If I "abandon" some coils, how should they be wired? Solder leads together, or leave them open?
The next question that I am pondering is whether the thing could be rewired in the future to use points to switch the polarity on the coils and build an electric start mechanism into the generator.
That will have to be some future experimentation. But, in theory, if I added permanent magnet activated points (selenoid)... I could convert this into a self "starter".
---- Clifford -----
BTW... I think the Honda EX350 and EX500 generators are quite likely to be basically the same except that the EX350 has AC/DC operation and I believe that the EX500 has AC ONLY operation. |
