| Will the LM7812 allow a lower (than 12v) to pass. I hope to use it to better regulate power from bats to LED's In high wind gusts sometimes I will see voltage spikes going into the bats. I beieve this may be why my LED's are experiancing a short life. They will work fine for quite some time but get slowly dimmer and dimmer til some of the just plane go out. I have a dozen or so LED's all run as a separate circuit parallel to each other with thier own 470ohm resistor. Will a LM7812 control the voltage the LED's see while letting say 11 volts through when bats are lower. Is it normal to see 15-16volts into bats for a brief amout of time durring a high wind gust? |
131 Scoop users have viewed this posting.
