You know this hobby has got you if or when
By Old F, Section Rants & Opinion
Posted on Sun Dec 4th, 2005 at 02:04:05 AM MST
An old post  just for fun
When your magnet collection on the refrigerator weighs more than the refrigerator.
Electric motor re builders are coming to you for  spare parts and wire.
Any more to add?
Have fun with it
Old F
You know this hobby has got you if or when | 74 comments (74 topical, 0 editorial)
Re: You know this hobby has got you if or when (5.00 / 1) (#5)
by Zix (zixoclock(at)webtv.net) on Sat Dec 3rd, 2005 at 07:55:40 PM MST
When your wife calls you crying cos she just got back from getting a $6000 set of braces for little Suzy and the poor kid is stuck the the fridge door.-lol
Zix-----
Re: You know this hobby has got you if or when (5.00 / 1) (#7)
by henjulfox on Sat Dec 3rd, 2005 at 09:00:39 PM MST
When the forcast is for heavy wind and you think "nice weather".
Re: You know this hobby has got you if or when (4.00 / 1) (#27)
by Jerry on Sun Dec 4th, 2005 at 10:06:11 PM MST
Maybe all newbees should read all the above befor makeing that fatal desision the do re.
If there wife reads this first you know he ain't got a chance in &^%^$$ to do re.
Airheads Page
Re: You know this hobby has got you if or when (5.00 / 1) (#9)
by maker of toys on Sat Dec 3rd, 2005 at 09:20:53 PM MST
when you have to go to the hardware store to get a new screwdriver to fix the computer with because all your current ones have arc notches in the tips or are too magnetic.  (motor run caps can be awful hard on screwdrivers. . .  but better the screwdriver than me!)
when you're disapointed that the problem with your computer isn't your hard-drive and you won't be getting some more wedge mags from it. . . .
when the TV makes all sorts of wierd colors and you can't figure out why until you remember that the fridge is on the other side of the wall. . .
when you pass the 'lego' store in the local mall and start thinking about making a mill and genny out of the parts on display.
when you get a steel plate for the top of the work bench so you can make workholding fixtures out of stacked neos.
when there's a roll of magnet wire serving as a book-end.
and the capper for me:
 when you stick the wifes new credit card on the 'fridge with a 1" x 1/2" neo. . .
(from a freind of mine)
It's not a case of 'Save the planet,' it's a case of 'Save the humans.'
Re: You know this hobby has got you if or when (5.00 / 1) (#17)
by richhagen (richhagen (a t) Juno.com) on Sun Dec 4th, 2005 at 01:08:09 AM MST
When you just bought a bunch of gear hobs to cut gears to automate a mill to carve blades, and your making the gears so you can multiply the torque so that you can use smaller servos to draw less power.  -And you still have to finish the building you built to put the machine into.
When you look around yourself as you type and see two solar panels you still have to mount, some linear slides, a couple spools of wire and a mini-milling machine, Every note on your fridge and door is held on with neodymium magnets.  Oh and by the way, they make great 'no mar' mounts for picture frames on drywall if you can find a suitably located drywall nail or screw under the plaster to stick it to.  Also, if you already new the preceding.
I'm not here yet I don't think, but when you have more in horsepower in electric motors than in internal combustion engines.  --and you own three cars.
When a gust of wind takes a 'temporary' mount down on your roof and smashes your car window, -- and your more concerned about the turbine.  (this is hypothetical of course)
When your idea of a great vacation is driving to Colorado to look at Turbines at the OtherPower 'Research and Developement' facility located in the Rockies.
When your girlfriend/wife/significant other thinks you are nuts because of RE and none of the above have come true yet.  (warning sign)
When its 2AM on a Sunday Morning, you've just gotten home and you are responding to this post, or if you have Area 52 on your property.
Have Fun, Rich Hagen
Re: You know this hobby has got you if or when (5.00 / 1) (#41)
by motorhead2 (MarkE@newlondonwi.org) on Mon Dec 5th, 2005 at 03:25:16 PM MST
You tell your wife that she needs a smaller airgap.
Mark
Re: You know this hobby has got you if or when (5.00 / 1) (#46)
by hiker (hiker.wild[at]yahoo[dot]com) on Mon Dec 5th, 2005 at 11:16:47 PM MST
and she replies-NO you need a bigger rotor shaft...............lol.
WILD IN ALASKA
Re: You know this hobby has got you if or when (4.00 / 1) (#53)
by motorhead2 (MarkE@newlondonwi.org) on Tue Dec 6th, 2005 at 03:34:13 PM MST
Then I say my tsr is too high for your permability.
Mark
Re: You know this hobby has got you if or when (5.00 / 1) (#48)
by pyrocasto (pyrocasto at hotmail dot com) on Mon Dec 5th, 2005 at 11:34:22 PM MST
When you look around and see almost $1000 worth of ebay cells laying around because you havent found the best way to mount them yet.
When you have to step over parts from printers and microwaves to get into the room.
When you realize that all your lights are cfls.
When you have multiple drawers dedicated to the storage of electronic parts from things you've scrapped over the years.
When you have a tub of dried coffee grinds for burning.
When you have a 5000 watt inverter sitting next to you that you bought because it was a "good buy", when a 500 watt inverter is all you truely needed at the time.
When you put all your electronics on strips that you turn off at night.
When you have spools of used magnet wire laying around for the projects that you know  you will do wrong the first time.
When you're shopping and you find stuff that would work great for an RE application, but wasnt intended for that use.
When you spend an hour taking something apart for a switch and a LED that would have cost you $1.
When you see a gallon jug of mash every time you open the fridge because you havent found a free heater for a distiller yet.
When you spend that much time thinking of stuff to write on fieldlines.com at 1:32AM.
Re: You know this hobby has got you if or when (5.00 / 1) (#50)
by willib (willibur at comcast dot net) on Tue Dec 6th, 2005 at 08:49:53 AM MST
this has been going for about ten min.
http://www.otherpower.com/images/scimages/2965/Picture_207.jpg
this is 5 min. later
http://www.otherpower.com/images/scimages/2965/Picture_209.jpg
once it gets going it really puts out a lot of heat.
Carpe Ventum (seize the wind)
Re: You know this hobby has got you if or when (4.00 / 1) (#54)
by pyrocasto (pyrocasto at hotmail dot com) on Tue Dec 6th, 2005 at 05:30:34 PM MST
That I didnt know. I think I may try that now for whatever reasons I could think of using it. Maybe good to heat a still or someting.
Re: You know this hobby has got you if or when (4.00 / 1) (#49)
by willib (willibur at comcast dot net) on Tue Dec 6th, 2005 at 07:41:39 AM MST
coffee grounds make a nice sterno , when mixed with bacon fat. lol i've tried it..
strangely enough it gives off a pleasnt oder , with no smoke !!
Re: You know this hobby has got you if or when (5.00 / 1) (#58)
by Jon Miller (Fieldlines 'at' otherpower 'dot' co 'dot' uk) on Wed Dec 7th, 2005 at 01:06:13 PM MST
(User Info) http://www.otherpower.co.uk
You know this hobby has got you if or when:
You have 55 hard drive magnets which one day will be useful
When you spend three hours taking apart 2 ink jets, 1 lazzer and a dot matrix just for the stepper motors that then go into a latge box allong with 100's of other small motors just incase u find a way to make power from them
when you stop to pick up old dumped microwaves of the side of the road just for the magnets
When you relise that you have two modles of wind turbines sitting on you computer desk that you didnt know where there
When you (like Chris) take apart video players just for some free LED's and a small motor
When you find your self recycling about 10 old computers a month for the hard drive magnets and the motos out of the CD drives
when every bearing you pick up is keeped for use on 'my next turbine'
when you find your self at the age of 17 telling 5000+ people across the world on a website found by chanse all your strange collection habits.  This post is making me lol
Jon M www.otherpower.co.uk
Re: You know this hobby has got you if or when (4.00 / 1) (#59)
by Drives (drivesdeanw at yahoo.com) on Wed Dec 7th, 2005 at 07:44:37 PM MST
You know this hobby has got you when during a late night thunder storm you hear your Art Randolf blades making a loud noise every time the wind blows above 20 mph.
Even though it is dark, raining, and lightning you run out to your tower to examine it with a flash light.  Due to it being 30 feet in the air you can't make out anything wrong except that the turbine is not producing any voltage but spinning so fast the blades are invisible.
So, to save the turbine you go get 100' rope, and try your best cowboy imitation to lasso the blades and tie rotor down.  Mind you, your soaked, holding a soaking wet rope, and swinging it into the air with lightning striking all around the valley and hilltops.  After the umpteenth time (I'm a yankee, not a cowboy!) you get the blades to wind up the rope, and tie it off.  When the wife asks what the heck you were doing....you mention something about needing to check something in the barn, and "man is it raining outside!" as you wring your shirt out in the sink. Ha Ha.
FYI my engineering to calculate the proper size industrial, flat, toothed, timing belt between the motor shaft and turbine shaft was quite sound for up to a 40 mph wind....however we saw a 68mph gust, that probably ripped the teeth right off the belt. Ha Ha.
To this day it still amazes me the stupid things I do for this hobby.
Art's blades still look new, but they must have been going supersonic!
---------Dean-----------
Re: You know this hobby has got you if or when (4.00 / 1) (#60)
by nanotech (darrin(dot)moore(at)gmail(dot)com) on Wed Dec 7th, 2005 at 08:55:17 PM MST
[QUOTE Jon Miller] You have 55 hard drive magnets which one day will be useful [/QUOTE]
Can I e-mail you my address?  :D
I've got PLENTY of uses for those, just a very limited supply around this neck of the woods!!  :)
__________________________________________
My ship finally came in, but it was the Kobayashi Maru!
Re: You know this hobby has got you if or when (5.00 / 1) (#64)
by phil b (philb7369at-no-more spam-yahoo.com) on Sat Dec 10th, 2005 at 06:02:16 PM MST
When your neighbors and your wife ask why you want their old treadmills that don't work because the bearings are bad, the belt won't stay on and why you already have two in your pickup...and you reply to make a wind generator???
Re: You know this hobby has got you if or when (4.00 / 1) (#1)
by ghurd on Sat Dec 3rd, 2005 at 07:10:25 PM MST
When you find a $200 box of magnets you forgot you had, and don't really know what you wanted them for.
Re: You know this hobby has got you if or when (4.00 / 1) (#2)
by dinges on Sat Dec 3rd, 2005 at 07:26:30 PM MST
When you see an air-compressor in the local dump and immediately think 'tank=batch water heater; motor=zubbly conversion. And no, this has NEVER happened to me. Absolutely. Positively. Really.
Peter,
The Netherlands.
Re: You know this hobby has got you if or when (5.00 / 1) (#6)
by windstuffnow (elenz(at)windstuffnow(dot)com) on Sat Dec 3rd, 2005 at 08:54:42 PM MST
  When you put two N50 4" diameter neo magnets in your back pockets to keep them separated and remember their back there just after you sat down on a metal bench...
  When you go shopping and all you see is wind generator parts... I find myself doing this all the time - things already made to use as something else other than what their made for...
Have Fun! Windstuff Ed
Re: You know this hobby has got you if or when (4.00 / 1) (#8)
by ghurd on Sat Dec 3rd, 2005 at 09:02:56 PM MST
When you put two N50 4" diameter neo magnets in your FRONT pockets...
Re: You know this hobby has got you if or when (4.00 / 1) (#20)
by windstuffnow (elenz(at)windstuffnow(dot)com) on Sun Dec 4th, 2005 at 10:15:40 AM MST
  That could be painful and embarrassing at the emergency room !   I'll have to remember that one.
Re: You know this hobby has got you if or when (4.00 / 1) (#39)
by asheets on Mon Dec 5th, 2005 at 02:43:15 PM MST
You see, I always think -- oooh, free air compressor.  Now where did I put that spare motor and regulator?
Alan Sheets
Re: You know this hobby has got you if or when (4.00 / 1) (#4)
by The Professor on Sat Dec 3rd, 2005 at 07:49:12 PM MST
  When you happen to see scrap lumber or wood pallets and examine them for knots and blade material suitability.
  Or visiting the junkyard: Oh look at those big carbon brush holders, hmmm. What's the name plate rating on that big electric motor in that pile? What's the ratio of that gearbox, it sure has a big output shaft. Should I buy it or hide it away in case I ever make that 30 ft. dia. wind mill? Look at that tub of stainless steel sheet and tube, it must have cost a fortune new. Is any of it right for the wood gasifier that I want to build?
Re: You know this hobby has got you if or when (4.00 / 1) (#10)
by Norm (peppysue@suite224.net) on Sat Dec 3rd, 2005 at 09:25:36 PM MST
   When you start wondering how many 2 liter
pop bottles made into savonius, it would take
to drive a generator large enough to get off
the grid....and the strongest wind you've seen
in weeks is about 6mph.
                  ( :>) Norm.
( :>) Norm
Re: You know this hobby has got you if or when (5.00 / 1) (#11)
by hiker (hiker.wild[at]yahoo[dot]com) on Sat Dec 3rd, 2005 at 10:20:08 PM MST
when the dryer has been broke down for over a month--and you lie to your wife that its un fixable--all the while knowing its just a heating element..dam that motor looks good for a gen....
WILD IN ALASKA
Re: You know this hobby has got you if or when (4.00 / 1) (#12)
by ghurd on Sat Dec 3rd, 2005 at 10:26:22 PM MST
At least 6mph registers on our meters.  :-/
Re: You know this hobby has got you if or when (5.00 / 1) (#14)
by Jerry on Sat Dec 3rd, 2005 at 11:50:44 PM MST
Like staying up way to late when you should have gone to bed 2 HRs ago and typing silly stuff on a wind power board?
Airheads Page
Re: You know this hobby has got you if or when (4.00 / 1) (#13)
by willib (willibur at comcast dot net) on Sat Dec 3rd, 2005 at 11:05:03 PM MST
How about all of the above and then some.
Like when you spend every waking hour thinking about generating POWER.
Like sticking cloth to your fridge with neos and spraying the  cloth with water to keep it cool so it wont come on as much. ( although not so much lately, with winter.)
Like NOT being able to drive by stuff , people have thrown out, without thinking Hmmm i wonder if there is anything in there i could use...
Re: You know this hobby has got you if or when (4.00 / 1) (#52)
by cyplesma (cyplesma@aol.com) on Tue Dec 6th, 2005 at 02:16:47 PM MST
/Like NOT being able to drive by stuff , people have thrown out, without thinking Hmmm i wonder if there is anything in there i could use.../
I do this all the time not just for re.
Re: You know this hobby has got you if or when (4.00 / 1) (#67)
by crashk6 (crashk6(at)solarstormtechnologies(dot)com) on Sun Dec 11th, 2005 at 06:31:23 PM MST
Ha.. I know what you mean, dumpster diving is a fairly normal activity for me. I've also had my fare share of law officers become VERY upset when they find me rummaging thru discards but find out from dispatch they can do nothing to stop me as I obey private property, no diving and the like signs. Sure is fun to pop your head out and startle the dickens out of em though! I've been known to tell people all my good stuff come out of the trash... LOL. Amazing the scale of sensless wastfullness in the world isn't it...
crashK6
Re: You know this hobby has got you if or when (4.00 / 1) (#68)
by willib (willibur at comcast dot net) on Sun Dec 11th, 2005 at 08:14:52 PM MST
yeah , one mans junk is anothers ...,
somone threw out what looked like pipe organ parts keys and all , a bench  and two air pumps (organ type real old..)
Re: You know this hobby has got you if or when (4.00 / 1) (#69)
by willib (willibur at comcast dot net) on Sun Dec 11th, 2005 at 08:20:00 PM MST
and a really nice ornate cast iron grate , its probably still there.
there was also a cast iron bench ,just one side though , i would have taken that if there was two..
Re: You know this hobby has got you if or when (4.00 / 1) (#15)
by DanG on Sun Dec 4th, 2005 at 12:22:05 AM MST
Odd lengths of magnet wire were used in half the household repairs you've made in last six months.
The cat still sports blue glass shards in its fur sometimes from the eBay solar cells you sorted a year ago.
You keep hard drive mags on string in car ashtray to fish in dumpsters too nasty to dive in.
Your bookmarks folder links could be published as a RE DIY referance library.
Re: You know this hobby has got you if or when (4.00 / 1) (#47)
by pyrocasto (pyrocasto at hotmail dot com) on Mon Dec 5th, 2005 at 11:21:39 PM MST
HA! My bookmarks can teach you alot about almost anything RE. I need to start selling the links! ;-)
Re: You know this hobby has got you if or when (4.00 / 1) (#16)
by anchor1 on Sun Dec 4th, 2005 at 12:42:39 AM MST
When you've spent more on tools than
you'll ever get back in this lifetime.
Re: You know this hobby has got you if or when (4.00 / 1) (#18)
by kenputer on Sun Dec 4th, 2005 at 05:56:55 AM MST
First and last thing you do everyday is check wind speed monitor and one last look out the window to see if blades are turning.
kenputer
Re: You know this hobby has got you if or when (4.00 / 1) (#19)
by Breezee on Sun Dec 4th, 2005 at 09:25:24 AM MST
When your wife asks you what you want for Christmas and you tell her a  $2000.00 lathe so you can turn rotors for motor conversions...
Re: You know this hobby has got you if or when (4.00 / 1) (#21)
by ruddycrazy on Sun Dec 4th, 2005 at 02:22:10 PM MST
To elaborate on Breezee, when you buy your wife a lathe for christmas and tweak the fisher an paykel washing machine so you can tell your wife it's buggered and we need a new one.
Re: You know this hobby has got you if or when (4.00 / 1) (#22)
by nanotech (darrin(dot)moore(at)gmail(dot)com) on Sun Dec 4th, 2005 at 02:52:58 PM MST
When your son begins to think his first name is Turn, as in "Turn Off That Light, You're Wasting Electricity!!"
Re: You know this hobby has got you if or when (4.00 / 1) (#23)
by stevesteve (houseonline (at) hotmail (dot) com) on Sun Dec 4th, 2005 at 04:46:12 PM MST
Oh Joy!
Other folk collect stuff on the fridge too... my fridge top carries a collection of neos, bearing for a mini-turbine, saw blades waiting to be converted etc.
You know when your obsessed when:
You go on a sea crossing with a beautiful view... and spend your time hanging over the side trying to photograph the harbour lights with solar panels.
You get caught in a huge traffic jam on the motorway but are happy to be stuck next to a light-up display board, just so you can get a good look at the mini wind and solar panel system that runs it's batteries.
You stop at a beautiful beach, Sandbanks on the southern UK coast and break in to the education centre to get photos of the down-wind turbine they have (OK actually I'm a member of the National Trust that runs the centre so I figured that I had partly paid for the gate I climbed over!).
Cheers, Steve
Re: You know this hobby has got you if or when (5.00 / 1) (#24)
by mikey ny on Sun Dec 4th, 2005 at 08:26:43 PM MST
you know your hobby has gotten you when you have more vege-oil in your garage than the local chinese restaurant can use in a month. Your wood pile is longer than the checkout line at wallmart the day before christmass. Your neighbor asks you what his old picture window is doin on you roof. The local scrap yard sends you a sales flyer in the mail. Your mother in law can't  move in (thank god) because her crap don't stink (methane digester).
                                                Mike
Mr. Mikey... "I thought I made a mistake but I was wrong"
Re: You know this hobby has got you if or when (4.00 / 1) (#25)
by aogden (abogden@sbcglobal.net) on Sun Dec 4th, 2005 at 09:26:25 PM MST
If you keep thinking wind energy even though you have not seen more than one hour of wind over 10 MPH in the last month.
Re: You know this hobby has got you if or when (4.00 / 1) (#26)
by electrondady1 on Sun Dec 4th, 2005 at 09:31:58 PM MST
your on a first name basis with the local machineist
Re: You know this hobby has got you if or when (4.00 / 1) (#28)
by hiker (hiker.wild[at]yahoo[dot]com) on Mon Dec 5th, 2005 at 04:54:37 AM MST
i think of it more than just a hobby--great bunch of guys that like to tinker or build things with their own two hands..kind of a dying race these days..but on the plus side of that statement--this board has created a whole new generation of tinkers -no dou"t!!
all in all its been the best place on the web-that ive ever been...
gotta admit, i havent kicked up as much dust on the trails these days..been tied down in the shop............later
WILD IN ALASKA
Re: You know this hobby has got you if or when (4.00 / 1) (#34)
by ghurd on Mon Dec 5th, 2005 at 10:53:28 AM MST
the local machineist slaps the CLOSED sign up when he sees your truck
Re: You know this hobby has got you if or when (4.00 / 1) (#44)
by Old F on Mon Dec 5th, 2005 at 06:11:13 PM MST
All I have to do is look in the mirror  Oh you said local not loco machineist
Never mind   :  )
Old F
Re: You know this hobby has got you if or when (4.00 / 1) (#29)
by DanB (danb@*no spam*otherpower.com) on Mon Dec 5th, 2005 at 08:02:57 AM MST
...  you find yourself dreaming at least once a week about towers crashing and wind turbine failures.
Re: You know this hobby has got you if or when (4.00 / 1) (#31)
by MattB on Mon Dec 5th, 2005 at 09:23:20 AM MST
Or in Scott's case...
... you find yourself repairing a failed windturbine at least once a week after it crashed into the tower.
Re: You know this hobby has got you if or when (4.00 / 1) (#30)
by Bruce S (bruce(dot)stahl <at>gmail (dot)(com)) on Mon Dec 5th, 2005 at 09:19:41 AM MST
You have more magnets that your son has baseball cards.
Re: You know this hobby has got you if or when (4.00 / 1) (#40)
by asheets on Mon Dec 5th, 2005 at 02:46:49 PM MST
when you have more dead hard drives on your desk waiting for dissasembly that your sons have matchbox cars on the carpet.
Alan Sheets
Re: You know this hobby has got you if or when (4.00 / 1) (#32)
by TomW on Mon Dec 5th, 2005 at 10:19:09 AM MST
Or .... you have an n45 grade NEO the size of a pack of cigarettes that you use to hold notes to your shop wall.
T
Re: You know this hobby has got you if or when (4.00 / 1) (#33)
by ghurd on Mon Dec 5th, 2005 at 10:50:56 AM MST
And the shop wall are made of wood!
Re: You know this hobby has got you if or when (4.00 / 1) (#35)
by ghurd on Mon Dec 5th, 2005 at 10:55:38 AM MST
You buy expensive stuff that will work.
Even if you do not have a use for it.
Re: You know this hobby has got you if or when (4.00 / 1) (#36)
by DBGenerator (dbrick3@yahoo.com) on Mon Dec 5th, 2005 at 11:49:58 AM MST
"Your neighbor asks you what his old picture window is doin on you roof. The local scrap yard sends you a sales flyer in the mail."
That and the one about being glad to be stuck in traffic just so you can see how the light up sign works are the best.
"When you have trash day marked on your calendar and you and your kid have the neighborhood split up into sections for locating reuseable appliances!"
"You needed a bigger wagon to put appliances in from trash night!!"
Dave
Re: You know this hobby has got you if or when (4.00 / 1) (#61)
by Gagster on Thu Dec 8th, 2005 at 10:44:42 AM MST
Darn you guys! You've infected me. I found myself looking at a TV in someone's trash pile today as I drove to work and a washing machine across the street. Unfortunately, I don't have a shop yet and I'm not quite ready for a divorce so I had to leave them be.
Re: You know this hobby has got you if or when (4.00 / 1) (#37)
by deloiter (iowa50070@aol.com) on Mon Dec 5th, 2005 at 12:02:56 PM MST
You know it's gone too far when:
When you walk the dog and he knows to head for the tower first.
You check several wind-power related discussion boards before you check the company's servers when you get to work.
deloiter
Re: You know this hobby has got you if or when (4.00 / 1) (#38)
by laskey on Mon Dec 5th, 2005 at 01:28:47 PM MST
When your dump load does a better job of heating the house than your funace (don't I wish). :)
Cya,
Chris
Re: You know this hobby has got you if or when (4.00 / 1) (#42)
by willib (willibur at comcast dot net) on Mon Dec 5th, 2005 at 05:46:36 PM MST
Like when you see a tree stump ( a real tall one , but with no branches )and think wouldnt that make a nice tower!!
Re: You know this hobby has got you if or when (4.00 / 1) (#43)
by jmk on Mon Dec 5th, 2005 at 06:07:04 PM MST
 When you buy two extra magnets just to play with.
 When your drivers door has dents in it from getting to close with the two magnets in your front pocket.
 When the soup cans fly of the shelf when you shop.
 When you have riped your front pocket becouse you didn't know there was a magnet strip at the U-Scan at the grocery store.
jmk
Re: You know this hobby has got you if or when (4.00 / 1) (#45)
by dinges on Mon Dec 5th, 2005 at 08:36:08 PM MST
When you feel like taking up the competition with the grid power companies, thinking you can beat their prices & reliability.
When having a grid power outage, all the neighbours lay out extension cords that end in your house; with you being the central spider in the web. Do this once, and they'll never again file a complaint on those 'ridiculous, bird-killing' windmills :-)
Peter,
The Netherlands.
Re: You know this hobby has got you if or when (4.00 / 1) (#51)
by BrianK on Tue Dec 6th, 2005 at 02:06:07 PM MST
when u become an expert welder    that is after your wind gen came crashing through the garage roof   but still not a carpenter hole in roof still there   dont ask me how i know but i do like that new skylight
Re: You know this hobby has got you if or when (4.00 / 1) (#55)
by Propwash (kgrindle@adelphia.net) on Tue Dec 6th, 2005 at 06:34:52 PM MST
its midnight,  twenty degrees, you hear wind gusts,jump out of bed, run for mill tower,  your in your slippers, holding a flashlight, checking voltage readings cause you can't afford a Trace c40 and didn't think you needed one anyhow. Been there, done that.
                        Kevin
Re: You know this hobby has got you if or when (4.00 / 1) (#56)
by ghurd on Wed Dec 7th, 2005 at 06:50:21 AM MST
When you have it so bad, the neighbors start catching it.
When the 85 year old guy next door goes out at 2:00AM, with his cane, in 9'F, 4" of snow, and whacks the ruler blades to see if they are frozen. They were not.
And you were watching out the window.
Re: You know this hobby has got you if or when (3.00 / 1) (#57)
by Gary D on Wed Dec 7th, 2005 at 11:03:04 AM MST
Love that one G....   :-)
Re: You know this hobby has got you if or when (4.00 / 1) (#63)
by tecker on Sat Dec 10th, 2005 at 09:00:58 AM MST
When your note pad has grown into your black book and for all intents and purposes are now the same with a tiewrap holding it together.
Re: You know this hobby has got you if or when (3.00 / 0) (#66)
by willib (willibur at comcast dot net) on Sun Dec 11th, 2005 at 06:17:15 PM MST
tecker if you would , drop me an email  i have a question or two i would like to ask.?
Re: You know this hobby has got you if or when (3.00 / 0) (#70)
by willib (willibur at comcast dot net) on Tue Dec 13th, 2005 at 06:51:49 AM MST
ok i'll ask here , what is the IM000065.jpg in your photos??
that looks real interesting , but i cant tell what it is?
Re: You know this hobby has got you if or when (4.00 / 1) (#65)
by Wolvenar on Sun Dec 11th, 2005 at 05:41:18 PM MST
(User Info) http://www.anotherpower.com/gallery/albums.php
You add a second posting for this, somewhat mirroring  an older you created almost two years ago.
See here
You actualy read this long thread
You spend all this time to read all this and find you mirror most of this,
After years of this hobby your wife started getting interested in just why this intriques you so much, then got hooked herself.
You have been on this board so long ppl from your past find you because of it.
(even when you dont want them to)
irc.anotherpower.com
Re: You know this hobby has got you if or when (4.00 / 1) (#71)
by witapple on Tue Dec 13th, 2005 at 09:36:33 PM MST
When people pass you holding up the one finger simply because you saw a new windmill and slammed on your brakes to get a better look.. (yes I admit it)
When you get calls from numerous people who you dont know because they had questions about wind energy (insert solar etc) and everyone told them you might be able to help. (ok i admit on this one too)
Dan W.
Re: You know this hobby has got you if or when (4.00 / 1) (#72)
by ghurd on Wed Dec 14th, 2005 at 08:29:29 AM MST
When you are in the mall parking lot with 5 tiny windmills because it is the closest place with good wind... and you don't care what all the Christmas shoppers think.
Re: You know this hobby has got you if or when (4.00 / 1) (#73)
by willib (willibur at comcast dot net) on Wed Dec 14th, 2005 at 08:27:03 PM MST
how are those tiny windmills coming along ??
Re: You know this hobby has got you if or when (4.00 / 1) (#74)
by ghurd on Wed Dec 14th, 2005 at 11:14:50 PM MST
Just as expected. Not great.
Almost close to be good enough to rate nearly just a little barely short of functional. Hehe.
Re: You know this hobby has got you if or when (3.00 / 0) (#3)
by MelTx on Sat Dec 3rd, 2005 at 07:31:00 PM MST
 When you start slovering and snareling when someone meerly blink their eyes, if they are looking at you creatures.
Re: You know this hobby has got you if or when (3.00 / 0) (#62)
by Jon Miller (Fieldlines 'at' otherpower 'dot' co 'dot' uk) on Thu Dec 8th, 2005 at 12:20:43 PM MST
Of course you can,  fldec@otherpower.co.uk :)
  232 Scoop users have viewed this posting.
· Also by Old F
