Hello All I have 4 motor convert gennys on line trying to charge 3 115 ah batts a total o.f 315 AH battery bank.Each gen is rectified, with its own blocking diode on the postive wire and tied to a juction strip.Then the D.C. is fed to about 1k mfd caps, with another blocking diode between them and the batts.The open volts between the caps and the batts is 30 up to 75 VDC depending on the wind.Well as usual the batts drag the volts down to about 13.If I hook a multi-meter in between the caps and the last diode,with the meter set on 10A the amps read .100 or some times .400
The batts do charge but not much.Does all this seem right,it seems that there should be more charging going on.I thought about the I-E-R thing but how do you get the R factot without letting the smoke loose.Can some one explain what hapens to the 75 volts in realation to the amp output. Thank you for your help |
105 Scoop users have viewed this posting.
