Battery minder, battery defender, or ?
By zmoz, Section Controls
Posted on Tue Mar 01, 2005 at 07:42:25 AM MST
Are these things worth the money?
I need a charger that will charge both SLA batteries and plan old flooded batteries. I am looking at either:
Battery Defender
http://www.batterymart.com/battery.mv?p=ACC-1206WB
Or
Battery Minder
http://www.batterymart.com/battery.mv?p=VDC-12112
Are these things any good? Are they worth the extra money over a $10 charger without a desulphator? Will they do a good job with both sealed and non sealed batteries? Are there any other chargers for around $50 that are better?
Battery minder, battery defender, or ? | 3 comments (3 topical)
Re: Battery minder, battery defender, or ? (3.00 / 0) (#1)
by Volvo farmer on Tue Mar 01, 2005 at 05:48:08 AM MST
What type of charging are you planning on doing? The first charger you listed only charges at 3A and the second is only 1A. If you'll repeatedly be charging up heavilly discharged high Ahr batteries, you'll want a charger that has a higher amp rating. My Schumaker supposedly has a desulfater in it. I'm not sure what to think of this technology. I haven't been able to bring any dead batteries back with it yet and I haven't done enough testing on old batteries to see if it makes a difference or not. Sam's club has a 2/20/70 Schumaker for about $50. Like this one.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=63687&item=7958508236& rd=1&ssPageName=WDVW
Volvo Farmer
Re: Battery minder, battery defender, or ? (3.00 / 0) (#2)
by ghurd on Tue Mar 01, 2005 at 06:18:59 AM MST
I use the Deltran Battery Tender, 800ma, waterproof.  This is the only charger I ever found that is actually regulated to 13.7 Volts, making it good for very small SLAs (7ah).  It is a switching regulator, making it work on a mod sin wave inverter, and uses less than 1 watt after the battery reaches 13.7v.
I use them for small SLA batteries around the house, and on 35ah SLA batteries for back up sump pumps.
http://www.batterystuff.com/productdisplay.html?id=329&c=181&f=Battery_Tender_Jr_12_volt_cha rger
But those sound similar.
My gripe is most chargers will get a 5 or 7ah battery cooking at 16v quick, No matter what the box says.
The 3.26MHZ seems a little fast for a desulfator ?
Like Volvo Farmer said- They don't put out many amps.
Ghurd.info
Re: Battery minder, battery defender, or ? (3.00 / 0) (#3)
by zmoz on Tue Mar 01, 2005 at 02:22:33 PM MST
I only need something small...I've got a couple gas powered chargers if I need quick charging.
  77 Scoop users have viewed this posting.
· http://www .batterymart.com/battery.mv?p=ACC-1206WB
· http://www .batterymart.com/battery.mv?p=VDC-12112
· Also by zmoz
