to pickster
By iFred, Section Controls
Posted on Mon Mar 14, 2005 at 09:44:37 PM MST
found problem
I checked out the genny, measured everything, all is fine. The problem was a bridge rectifier which was used had for some reason shorted internally, which can happen. As soon as I did the tests and removed the bridge everything returned to normal. Your generator is fine just to let you know! wiring is good. see you in a couple days.
Good Luck!
Fred.
to pickster | 1 comment (1 topical)
Re: to pickster (3.00 / 0) (#1)
by monte350c on Mon Mar 14, 2005 at 03:32:53 PM MST
Pat on the back there Fred.
Fixing stuff is the easy part.
Finding out what's wrong and doing the diagnostic stuff is always the hardest.
Ted.
  72 Scoop users have viewed this posting.
· Also by iFred
