I figured it wasn't quite finished without a nose job. It's made of 5 layers of high density foam insulation disks glued together on a 16" x 3/4 " plywood disk. A 3/8" bolt was screwed into a "T" nut in the center before gluing the foam on and then was chucked into my cordless drill. Took a rasp to it at slow speed to rough the shape and then smoothed it by sanding it the same way. About 3 coats of Wests System Epoxy again sanded the same way between coats and finally a few coats of gloss white enamel. It's very light and lag bolted through the back side of the front hub plate with 2 stainless bolts between each blade. A bead of white silicon caulk along the edge when I bolted it on seals it up. Might need just a slight tweeking of balancing but it all seems very close to what it was and runs very straight and true. It was a fun project and may just help the performance a bit besides. I can't remember who else out there laid the ground work for me on this but thank you, I just needed to get at it. Dave B.
181 Scoop users have viewed this posting.
