wood gas
By mikey ny, Section Heat Posted on Tue Mar 29th, 2005 at 01:44:45 PM MST
converted burner gun
Hello all,
I am abit new to this forum. I am experimenting with wood gas and gasification. My summer project will be to convert a gas burner gun to burn wood gas. I am going to try to draw the wood gas produced from a downdraft gasifier into a 275 gal. oil tank, useing a small vacume pump, Then i will use air pressure to force it into some empty propane tanks so i will have gas for later use. It sounds simple enough but i know i will have some problems. My oil tank may buckle under too much vacume and my gasifier will not operate with too little vacume. It may also be dangerous because the gas will be volitle. Anyone ever try this? How dangerous could it be. |
wood gas | 33 comments (33 topical, 0 editorial)
161 Scoop users have viewed this posting.
