not sure if it's a pure sine inverter tho
paul
If yes, could a very small alternator be used? The alternator could be driven by a motor or if the unit required a cooling fan, the alternator could run from the same motor as the fan... could the same alternator be monitored and the motor speed adjusted accordingly to ensure the correct frequency?
'As is' would this circuit be any good for running 240v CFL's?
cheers, paul
Not sure where you came up with 1.707
To convert rms to peak multiply by 1.414 To convert peak to rms multiply by 0.707 To convert rms to peak to peak multiply by 2.828 To convert peak to peak to rms multiply by 0.3535 To convert rms to avg multiply by 0.9 To convert avg to rms multiply by 1.11
Right out of any book.
12v rms = 33.936 v peak to peak
John[ Parent ]
