Composting toilet installation
By chibear, Section Diaries
Posted on Wed Mar 30, 2005 at 01:14:26 AM MST
From box to basement
I spent the last few days installing my Sun-Mar 3000 composting toilet. The unit is now installed and finished to floor level. There is still snow on the roof, so the final installation will have to wait a week or so.
Initial observations:
  1. The body of the composter is of very high quality fiberglass construction and the instructions quite clear.
  2. There were several parts missing. Sun-Mar had them to me in less than a week. Some screws, etc I had in my shop.
  3. While the body of the composter being fiberglass is a good thing, the doo-doo chute and adapter are also fiberglass. The moulded pieces did not match up exactly and the pre-drilled holes did not match up at all. I needed C clamps to hold the pieces in alignment while I re-drilled the new holes. The toilet, chute, adapter, and composter fit together very loosely, soooo LOTS of silicone, a lot more than Sun Mar gives you for the project.
  4. The venting system is central vac tubing, so went together in a snap. This unit must be vented separately through the roof in order to eliminate odor.
Update with pictures after unit is up and running.
Composting toilet installation | 9 comments (9 topical)
Re: Composting toilet installation (3.00 / 0) (#1)
by hiker on Tue Mar 29, 2005 at 07:55:11 PM MST
i vented mine out the back--no sence in wasting all that natural gas..
gets about ten miles to the dump...........................  ;}
WILD IN ALASKA
Re: Composting toilet installation (3.00 / 0) (#4)
by LEXX on Tue Mar 29, 2005 at 09:57:36 PM MST
Wow, that must be my mother-in-law in there!!
LEXX
Re: Composting toilet installation (3.00 / 0) (#5)
by chibear on Wed Mar 30, 2005 at 09:12:01 AM MST
ROFL..... If only it were true, I could run my Rinnai off my toilet.
Re: Composting toilet installation (3.00 / 0) (#6)
by newguy on Thu Mar 31, 2005 at 05:47:50 PM MST
dude where can i get more info on this thing what a flame
Re: Composting toilet installation (3.00 / 0) (#7)
by hiker on Thu Mar 31, 2005 at 08:43:18 PM MST
google search---jet powered outhouse
WILD IN ALASKA
Re: Composting toilet installation (3.00 / 0) (#10)
by wooferhound on Sat Apr 02, 2005 at 12:29:47 AM MST
more info
http://www.popsci.com/popsci/how2/article/0,20967,783909,00.html
W o o f -={(
Re: Composting toilet installation (3.00 / 0) (#11)
by wooferhound on Sat Apr 02, 2005 at 12:37:19 AM MST
and then there is always the Jet Powered Bar Stool
W o o f -={(
Re: Composting toilet installation (3.00 / 0) (#9)
by stm on Fri Apr 01, 2005 at 02:23:06 PM MST
That is definately the worst place to smoke a cigarette...
/steffen
Re: Composting toilet installation (3.00 / 0) (#8)
by ghurd on Fri Apr 01, 2005 at 08:22:02 AM MST
Don't know if this helps, but I changed the fan in one to a muffin fan.
Kind of a sloppy fit.
Still works fine, uses a lot less battery.
No idea what brand toilet it was. It was using 4" white plastic dryer vent.
Ghurd.info
· chibear's Diary
