Rediscovered BTHumbles meter dial program
By richhagen, Section Controls
Posted on Thu Mar 31, 2005 at 04:58:16 AM MST
Volvo Farmer was kind enough to share a bunch of meters and a couple tricks
A while back Volvo Farmer and I shared a batch of amp meters from E-Bay.  He introduced me to a neat trick he learned from somewhere or other.  The meters were the type that you pass the wire through a cage to measure the DC amps in the wire.  The trick was that you could loop the wire a couple or more times to change the scale of the meter to a lower value.  The meters were 80 Amps, so for example if you looped a smaller cable through the slot 4 times, it yielded a 20 amp meter.  The only thing was that the scale in the back was still for an 80 amp meter.
Anyway, I was looking through the old files and noiced a posting from BT from a year or so ago.  It was a visual basic program for generating the meter display backing.  Within about 10 minutes I had it figured out and was looking at a nice 20 Amp scale background for the meter.  It was a beautiful thing.  Rich Hagen
Rediscovered BTHumbles meter dial program | 2 comments (2 topical)
Rediscovered BTHumbles meter dial program (3.00 / 0) (#1)
by richhagen on Wed Mar 30, 2005 at 09:59:32 PM MST
Oh yeah, I forgot to put a link to that story:
http://www.fieldlines.com/story/2004/2/3/191649/8833
Rich Hagen
Re: Rediscovered BTHumbles meter dial program (3.00 / 0) (#2)
by BT Humble on Thu Mar 31, 2005 at 02:49:04 PM MST
Hooray!  I'm always pleased when my work is of use to someone else as well. ;-)
BTH
  109 Scoop users have viewed this posting.
· Also by richhagen
