Another abstract idea
By nanotech, Section Wind
Posted on Tue Apr 12, 2005 at 06:09:51 PM MST
Continuing with another poster's idea....
In this thread, there was an idea of a dual prop generator brought up.
Well, the idea was kind of shot down due to turbulence for the rear prop from the front one.
I was wondering what you folks thought of this idea.
The left side blade set would be set to "bend backward" away from thier hub. That way if the wind got too high, it would furl its blades and turn the whole assembly out of the wind. I haven't drawn a tail yet, but it would point away from us as we are looking at the pic.
So, what do you folks think? Am I making a mountain out of a molehill here, or could this be a way to get two generators on one mast? Would this work? Or am I looking at two big holes dug in the ground when it all succumbs to gravity? :)
Another abstract idea | 6 comments (6 topical)
Re: Another abstract idea (3.00 / 0) (#1)
by kitno455 on Tue Apr 12, 2005 at 02:01:41 PM MST
ok, i was thinking about a dual rotor this way myself. makes each half of the gen easier to build, but still has a bit of surface area. only one tower, seems ok as a basic idea. points to the dual mill.
power is related to the cube of the swept area, so it should be easy to figure out just where a single big rotor is better than a pair of smaller ones. a pair of 3 blade 10 footers is 157 feet swept. that makes 30 feet of thinner blades. a single turbine would have to be 14 feet across to have the same swept area. thats only 21 feet of thicker blades. points to the big mill.
however, i think that you will still need a tail behind this thing, and that is going to fight your attempt to yaw some. having the two props unequal seems like a bad idea, you have to make twice as many custom parts, and potential for more bobbing in the wind as one of them flexes. you also need two gens, or right angle drives, or a belt setup. twice as many rectifiers, etc. points to the big mill for simplicity.
so it comes down to only one reason i would ever do this- if i already had a mill, but i only had room for one tower, and i did not want to scrap the old mill.
allan
Re: Another abstract idea (3.00 / 0) (#2)
by Peter V on Tue Apr 12, 2005 at 05:26:55 PM MST
Seems to me it would be easier to just mount them one above the other on the same mast and use independent, standard furling methods.
Re: Another abstract idea (3.00 / 0) (#3)
by nanotech on Tue Apr 12, 2005 at 07:25:24 PM MST
Yeah, it would. But I'm trying to get away from height as I live only 4 miles from the airport.... :(
__________________________________________
My ship finally came in, but it was the Kobayashi Maru!
Re: Another abstract idea (3.00 / 0) (#5)
by Peter V on Wed Apr 13, 2005 at 11:47:58 AM MST
You are only talking a little more than the diameter of one turbine, how big are your turbines??!!??
Re: Another abstract idea (3.00 / 0) (#6)
by Victor on Wed Apr 13, 2005 at 01:11:58 PM MST
  Four miles from an airport ! You will only need a determination by the FAA if you want to go over 200'.
Re: Another abstract idea (3.00 / 0) (#4)
by nothing to lose on Tue Apr 12, 2005 at 10:32:46 PM MST
I thought about doing something similar for 2 smaller mills on one tower.
Basically make it look like a 2 engine aircraft, or get fancy and a 4 engine bomber :)
 If it's useless junk for decoration only you can put up almost anything anywhere, but if it serves a usefull purpose people panic and you get hit with zoning, codes, restrictions, etc....
So, making a 2 gennie aircraft looking mill on one tower and hiding the wires inside the tower, it looks like a useless decoration or wind vane and probably no-one would complain about that in most areas! Plus it would look cool if nicely done.
In thinking about this alot, I have decided myself to keep it kinda small. Lots of stress on those pipes running out the sides, supporting the weight of the mill and the force of the wind trying to push them backwards. The more support you add the more you block the wind flow, plus more weight of course on the tower.
My thought is a small wing out each side, round body in the center over the tower, rear rudder as the furling. Perhaps to support the wings extend the tower a couple feet above the body, then run a thin guy wire to the outer wingtips.
Make sure it can't really fly in hard winds though!!
  88 Scoop users have viewed this posting.
· this thread
· Also by nanotech
