waste veggy oil fule
By phillipquinn, Section Remote Living
Posted on Fri Apr 15, 2005 at 05:10:02 PM MST
VEGGY FUEL
Iam new to the bord not shure this is the right area to post this but here it goes
i have been hearing about people mixing waste veggy oil with reg car gas and runing it as fule for cars does anyone have information on this i know all about using WVO
as fuel for Deisel eng. but not about reg gas ones any help i will be greatfull for
thanks
waste veggy oil fule | 9 comments (9 topical)
Re: waste veggy oil fule (3.00 / 0) (#1)
by jimjjnn on Fri Apr 15, 2005 at 11:30:47 AM MST
Don't do it !!!
I did this as a kid. Engine barely ran with 3 gallons of diesel in a 16 gallon tank with about 12 gallons of gas. Tried changing timing and running with wide open throttle. Barely ran and I had to creep in 1st gear all the way home with smoke pouring from the exhaust . At stop signs I made a big cloud of smoke that you couldn't see through. Of course that engine(235 cu inches) was low compression too, 6:1 ratio.
Ended up draining tank and carburetor rebuild.
Denver,CO
Re: waste veggy oil fule (3.00 / 0) (#2)
by phil b on Fri Apr 15, 2005 at 12:22:53 PM MST
Diesel engines, however, do run well on WVO. I use it in my pickup every chance I get.
Re: waste veggy oil fule (3.00 / 0) (#3)
by Aelric on Fri Apr 15, 2005 at 05:05:41 PM MST
Here is an excellent link for Biodiesel, a diesel substitute made from veggie oil, or any kind of fry oil.  It also has information about 2 people's trek accross america on Biodiesel.
http://www.homepower.com/magazine/downloads_transportation.cfm
2 pdf files, just need to get adobe acrobat to read them.
Have fun.
Re: waste veggy oil fule (3.00 / 0) (#4)
by nothing to lose on Sat Apr 16, 2005 at 02:53:20 AM MST
He said he knows about using it instead of diesel, wants to know about instead of gas. Links are good for others too of course that don't know yet.
I just found about a 500 galloon supply of the stuff and about 20-40 gallons a week!!
 Now to buy me a diesel ANYTHING!
Don't dump diesel in your gas tank for a gas engine IT WILL NOT WORK! It may ruin your engine also! Back around the late 70's I knew someone that used diesel by accident in a Cadilac with a nice big monster engine, high compresion too, it did not run on the diesel and he never got the car running right on gas again after that either. Now as far as veggie oil I expect it to be the same thing in that respect.
First, gas ignites by spark but oil does not. It takes the heat caused by high compresion to ignite the diesel. When you compress it in the cylinder heat builds up and it explodes. A gas engine normally just does not have that kind of compresion ratio's.
Now here is what I will be experementing with!
Gasolene vapors to ignite from the sparkplug as normal, waste oil to burn and create the power, water to cool the engine pistons.
Gas vapors will run an engine, just about everyone knows more gas is ran though the engine than is needed to run it, the extra unburned gas is used to cool the cylinders and also the reason we need catalytic converters to burn the unused raw gas in the exhaust pipe. Run an engine too lean (low gas high air mix) and it runs fine, untill the pistons melt and blow out! Or other damge could occure, burnt valves ect..
Gases are funny things, we cook with propane just fine, mix plain air with it using a blower and you can melt aluminum for casting parts! Gotta watch what you do inside an engine!
So, using feul injectors and some switches/sensors I am going to build a 2 and 3 feuled engine building my own carburator for it. Basically remove the existing Holley 4 barrel and build a new one with injectors. I will also need 3 feul pumps! 1 for gas, 1 for water, 1 for oil. That's the plan for my F250 truck.
My first try will probably be just gas/water on a junk Toyota van I have, runs great except the feul pump does not work in the tank and I don't like the van anyway. This will be a genterator ran often and see if I blow the engine, I have a second van exactly the same if I blow the enigne in the first, to try again :)
 Those are feul injected already, so I will remove those injectors.
For a carburator engine I will use a Ford 302 or 351. I have a 1/2 van with 302, F250 truck with 351. If I blow the engine in the truck I will install the 302 in it.
 I never liked 351 anyway and would rather have the 302 in the truck.
I would not try this on your daily driver that you depend on!! I have lots of spares, well over 30 here!!
And I am kinda building the carb from scratch, my own design for the mixing of the feuls.
Re: waste veggy oil fule (3.00 / 0) (#5)
by troy on Sat Apr 16, 2005 at 12:16:10 PM MST
As the others said, wvo (waste veggie oil) will NOT work in a gas burner.
Even in a diesel, it needs to be filtered down to less than ten microns and preheated to lower the viscoscity so it won't hurt your injection punp or fuel injectors sooner or later.  There are fuel systems that are very tolerant of unheated veggie oil, but they are rare.
Best regards,
troy
Re: waste veggy oil fule (3.00 / 0) (#6)
by nothing to lose on Sat Apr 16, 2005 at 07:19:54 PM MST
"Even in a diesel, it needs to be filtered down to less than ten microns and preheated to lower the viscoscity "
Ya I think I forgot to mention that part, which is included in my test toy along with a couple other things I did not mention.
Re: waste veggy oil fule (3.00 / 0) (#7)
by stevesteve on Sun Apr 17, 2005 at 01:03:28 AM MST
A word of warning though. It may actually be illegal to run a car in the UK on recycled veggie oil.
Why?... Tax! The gov. makes a shed load of money on each gallon we buy (now nearly £4 per gallon - that's about $7 per gallon).
If you use old veg oil you don't pay fuel tax to them and they don't like it!
RANTING POINTS:
Veg oil is probably lower in sulphur content than fossil fuel.
Veg oil is 'carbon neutral' ie the CO2 from the air is absorbed by the plants and turned into oil. We burn the veg oil and return the CO2 to the atmosphere but no net increase. Fossil fuels increase the glogal CO2 levels.
OK rant over but all our local chip shops have to pay to dump their old oil and I run a diesel car and I can't reuse their old oil.
Cheers, Steve
Cheers, Steve
Re: waste veggy oil fule (3.00 / 0) (#8)
by troy on Mon Apr 18, 2005 at 02:01:50 PM MST
I won't tell if you won't...
Sometimes, it takes a little civil disobedience to do the right thing!
You could always send in your fuel tax anonymously and keep scrupulous records of production, use, and receipts in case you get caught.  The judge would probably take a more gentle approach if it's obvious you're not trying to dodge the tax, just save the world's environment.
I dare you to do the right thing!
Good luck and have fun doing it!!!
troy
Re: waste veggy oil fule (3.00 / 0) (#9)
by 12volt dan on Sun Apr 24, 2005 at 08:36:03 AM MST
To true. I'm in a biodiesel forum where some guys from England have been tracked down from their posts and "caught" and forced to cough up the tax
11 years off the grid and counting
  109 Scoop users have viewed this posting.
· Also by phillipquinn
