PVC Pipe prop plans and History
By wooferhound, Section Diaries
Posted on Tue Apr 19, 2005 at 04:14:31 PM MST
This is why they call them ZubWoofer props
 I have been moving my better projects into my diary. But while I did draw up the plans for the PVC Pipe Props, Zubbly was
the one that pretty much invented them. This is why they are called ZubWoofer Props. So instead of reposting the Prop plans
in my diary, I decided to post the history and evolution of these props. Some fo the pictures in the earlier posts don't
show up because Zubbly was also learning how to post pictures at this time too.
Zubbly invents the PVC props and first mentions that he is making Props from Pipe
http://www.fieldlines.com/story/2003/9/7/16254/83196
Some of Zubbly's first descriptions of the Props he is making
http://www.fieldlines.com/story/2003/10/5/185824/882
The first good pictures of the PVC Props and discussion of durability
http://www.fieldlines.com/story/2003/10/19/171250/17
Plans are starting to emerge and Wooferhound is posting Drawings Too
http://www.fieldlines.com/story/2003/10/25/020/94523
Wooferhound starts making Props and makes a 4 Blade version
http://www.fieldlines.com/story/2003/10/29/17144/245
After talking on IRC chat Wooferhound decides to Draw Plans for the props
http://www.fieldlines.com/story/2003/11/11/172721/53
Wooferhound makes PVC Savinous experiment
http://www.fieldlines.com/story/2003/12/1/122243/608
And that is why they are called ZubWoofers
It's really cool for me because I am seeing pictures of them from all over the world
Recently 'stevesteve' a user in the UK wrote a computer program that greatly simplifys the measurements needed to cut one of
these blades out of the pipe. You can download the program from this story
http://www.fieldlines.com/story/2005/4/17/6437/83378
Happy first time cheap prop building from Wooferhound
PVC Pipe prop plans and History | 15 comments (15 topical)
Re: PVC Pipe prop plans and History (3.00 / 0) (#1)
by electrondady1 on Tue Apr 19, 2005 at 07:54:45 PM MST
thanks nice and dense information
Re: PVC Pipe prop plans and History (3.00 / 0) (#2)
by gizmo on Wed Apr 20, 2005 at 12:40:46 AM MST
I've been using PVC for my smaller windmills, but on a 3 blade propeller.
How will that calculator program work with 3 blades? I used Warlocks calculator to get the angles and it seams to work ok, but "stevesteve"'s would be a lot easier to use.
Glenn
www.thebackshed.com
http://www.thebackshed.com
Re: PVC Pipe prop plans and History (3.00 / 0) (#3)
by stevesteve on Wed Apr 20, 2005 at 01:56:39 PM MST
Glenn,
Should be OK for you. The calculator just works out the width of the paper template for required angles for a particular pipe diameter (angles and diameter set to your requirements).
I'm intending to do something similar myself. I am trying to locate some larger diameter pipe in the UK. I can only get 4" so far.
Cheers, Steve
Cheers, Steve
Re: PVC Pipe prop plans and History (3.00 / 0) (#5)
by nanotech on Wed Apr 20, 2005 at 05:26:50 PM MST
Find a construction company.  They should have up to 10 inch diameter pipes for commercial sewer lines.
Might have to sand the blades thinner, because at a 10 inch diameter, the pipe's going to be kinda thick.
Don't know whether shipping would kill you, but these guys have quite the selection.....
http://www.pipeplus.com
__________________________________________
My ship finally came in, but it was the Kobayashi Maru!
Re: PVC Pipe prop plans and History (3.00 / 0) (#8)
by stevesteve on Fri Apr 22, 2005 at 06:29:16 AM MST
They seem to be US based but I will check out some UK construction suppliers.
On the other hand a 3' or 4' section would do so I might cruise the local building sites touting for offcuts!
Cheers, Steve
Cheers, Steve
Re: PVC Pipe prop plans and History (3.00 / 0) (#4)
by MtnTopRebel on Wed Apr 20, 2005 at 02:44:48 PM MST
Humm might be a solution for me... I have an old gear drive Pre REA windmill, that needs blads.  The unit is designed for two blades but I might have to modify it to 4 and shorter blades....  guess I will need to dig it out get a pix and seek some advice...
Re: PVC Pipe prop plans and History (3.00 / 0) (#6)
by Peppyy on Wed Apr 20, 2005 at 08:43:18 PM MST
Hey, don't forget about these that charge my booster packs.
Pep
Re: PVC Pipe prop plans and History (3.00 / 0) (#7)
by Norm on Thu Apr 21, 2005 at 06:39:32 AM MST
    Do you have details on this one?
  Diameter of pipe used ....diameter of swept area...rpm in 6-8mph wind?
    Looks good!
              ( :>) Norm.
( :>) Norm
Re: PVC Pipe prop plans and History (3.00 / 0) (#9)
by windyknight on Sat Apr 23, 2005 at 10:07:39 AM MST
Whats merit in 4 blades vs 3 - cant seem to find info on pros and cons!
Just when you think things can't possibly get any worse- they usually do!
Re: PVC Pipe prop plans and History (3.00 / 0) (#10)
by Peppyy on Sat Apr 23, 2005 at 04:44:51 PM MST
I have some information on them here
http://www.fieldlines.com/story/2005/1/6/232942/4004
They were made from 4" pipe and are 48" long.
Windyknight, the only reason I made this a 4 blade setup was for use of material VS. strength. It was a whole lot easier than building a fancy hub and bolting everything together.
I have no scientific data to support it but from what I have read here in the last couple months I would be willing to bet I would get better performance from 3 blades. It has to do with what I call "Prop wash". At higrer rpm's the air is still disturbed when one follows the other at 90 degrees apart. With 3 you have 120 degrees between them allowing a bit more time for the air to settle back into it's path, thereby creating more power.
Of course, the swept area would be smaller, limiting the power factor and the startup speed so the low rpm performance would be slightly less. I guess it is a bit of a tradeoff and without some real test figures it is all theory.
Pep
Re: PVC Pipe prop plans and History (3.00 / 0) (#11)
by windyknight on Sun Apr 24, 2005 at 02:39:02 AM MST
Think there might be some torque benefits, I seem to recall most planes with 4 blade props were carriers rather than fighters but someone must have data! k
Re: PVC Pipe prop plans and History (3.00 / 0) (#12)
by jimjjnn on Sun Apr 24, 2005 at 08:39:40 AM MST
WWII  F4U(?) Corsair had 4 blades and 13 foot swept area. That was the reason for the  gull wing shape of it's wings.
Denver,CO
Re: PVC Pipe prop plans and History (3.00 / 0) (#13)
by Norm on Sun Apr 24, 2005 at 01:53:35 PM MST
   A four-bladed prop on a plane was supposed
to be quieter than a 2 or 3 bladed one.
             ( :>) Norm.
( :>) Norm
Re: PVC Pipe prop plans and History (3.00 / 0) (#14)
by rotornuts on Sun Apr 24, 2005 at 04:56:21 PM MST
"silent running" hellicopters such as the MD 500E utilized 5 blades instead of the standard 4 so they could reduce the rotors rpm and still generate the same lift. The reduced tip speeds yielded a noticably quieter rotor according to the manufacturer. "NOTAR" also dramaticly improved the noise levels.
Re: PVC Pipe prop plans and History (3.00 / 0) (#15)
by di34 on Wed Feb 20, 2008 at 08:28:33 AM MST
Hi Great information
Here is useful info Alise
  324 Scoop users have viewed this posting.
· http://www .fieldlines.com/story/2003/9/7/16254/83196
· http://www .fieldlines.com/story/2003/10/5/185824/882
· http://www .fieldlines.com/story/2003/10/19/171250/17
· http://www .fieldlines.com/story/2003/10/25/020/94523
· http://www .fieldlines.com/story/2003/10/29/17144/245
· http://www .fieldlines.com/story/2003/11/11/172721/53
· http://www .fieldlines.com/story/2003/12/1/122243/608
· http://www .fieldlines.com/story/2005/4/17/6437/83378
· wooferhound's Diary
