You can modify the TSR, the number of blades, or gearing ratio to see how that affects the size of the blades, but I sugest to stick with their default values unless you know exactly what you are doing.
So, find the output and RPM for your generator, insert them, get the suggested diameter, insert that value, and you got your blades pattern.
To find out your generator output, spin it at different rpm's and measure the volts and amps with some load, then find the power P=U*I for each RPM measurement.
Have Fun,
Speo [ Parent ]
station radius angle Chord A chord thickness(m) drop
Here is a link to the blades that I was talking about.
Speo.
