| Hi all,
Looking at some blade designs and a program, it occurred to me...
That the root section of carved blades should be very thick.
The ZubWoofer PVC blades are a lift design.
And the section near the root has a very poor angle of attack.
Looking at a drawing of the ZubWoofers would be helpfull here.
The numbers I will be using are just pulled out of thin air.
What I thought was to increase the root angle to maybe 30 degrees.
Then, for the trailing edge from the root to maybe 20% out toward the tip,
at the root mark 5 degrees into the blade, at 20% out mark the trailing edge,
and remove that material.
Visualize the cross section about 5 or 10% out from the root.
The angle of attack and lift should be improved.
The surface area would not change drastically, but the same idea as like starting with a very thick piece of wood for a carved blade to get a good angle of attack.
While the center 1/3 is only 11% of the power produced, I read,
It would also maybe increase the power from the rest of the blade,
because it would not be dragging the dead areas through the air.
That dragging and induced interferance in the air flow could be why they stall at a certain RPM?
The leading edge would be changed considerably, and may need adjusted accordingly.
Is this way off base?
I am not a blade guy. Does it show. LOL.
212 Scoop users have viewed this posting.
