| My goal is build a bicycle powered flywheel ( large about 200 pounds or more) that would average a 150 watt output. The rpm and therefore the watts would start much higher and spin down over the course of the day. I want to connect it to the grid with a net meter to avoid battery inefficency and cancel out my currenct utililty bill of 800 KW a month with the credits from my net metered flywheel. I've seen a few bicycle generators but nothing with a large flywheel.
I envision using the 45 pound freeweights used for bodybuilding as the flywheel. I imagine using at least four, don't know what the limit would be. I would build the flywheel frame using bicycle parts: A bicyle headtube on each side of flywheel (flywheel spins perpendicular to the ground, the flywheel mounted on a bicycle fork steerer tube, the steerer tube mounts in the headtubes with standard bicycle headset bearings. The headtubes are built into a metal frame to support all this. The bicycle is mounted in a standard rear wheel exercise stand. Take off the exercise resistance device and have bicycle rear wheel make direct contact with flywheel, just like the exercise resistance device does. I envision using a mountain bike with the wide gearing range of the triple crankset. I would hope I would only need to spin up the flywheel once a day but twice a day would be fine also, of course the bigger the family the more help.
I'm just a suburban husband whose wife thinks he is crazy already, so I need to build this thing slowly so the money spent won't be too noticable. I'm thinking a budget of 2-3 thousand, mostly for inverter and net meter. I'm a handyman but I do not even own a voltmeter; recommendations very much appreciated. My only concern is I could be wrong about how long the flywheel could spin, if it is only about an hour this won't work. My therory is the human body is an efficient torque machine, this combined with the triple crank set gears will make this work.
Many thanks for anybody's input.
200 Scoop users have viewed this posting.
