| ok, i know this is hard to test, but i am looking for a way to determine just what is the root cause of electron motion in a coil, as a magnetic field passes by.
i have an oscilliscope, and i have definately seen a decent looking sine wave using a single mag and a single coil. the bumps in the wave correspond with the mag passing directly over the two coil legs (sides) at that moment. there is no iron core or backing, i used a piece of wood as a handle for the coil.
so my dilema is thus: is it the lines of flux cutting the coil leg, or the change in flux density that causes the electron motion? i realize that the lines of flux are sort of 'virtual' way of describing density, so these two things are very nearly the same. but they are not exactly the same, as one is more the derivative of the other.
if you took an infinitely long magnet and passed it under one coil leg only, would you get a flat-topped bump in your wave, or would it continue to rise, or dip in the middle of the bump? i realize infinitely long is impossible, but what i am trying to say is: if the density of the flux above a mag is constant along its length, and it passes a bit of wire, is electricity produced?
allan |
67 Scoop users have viewed this posting.
