ECM motor blade and wiring
By iFred, Section Wind
Posted on Sun Jun 19th, 2005 at 11:42:13 PM MST
need some info
Any one have a decent wood blade layout for a standard ECM motor and wiring schematic for hookup? Thinking around 2ft or 2-1/2ft per blade should do it...suggestions? anyone work on this?
Thanks in advance!
ECM motor blade and wiring | 3 comments (3 topical, 0 editorial)
Re: ECM motor blade and wiring (3.00 / 0) (#1)
by ghurd on Mon Jun 20th, 2005 at 08:57:06 AM MST
Hi Fred,
Jerry did a lot of output testing on those, with Jerry blades.
Most of it was in the couple months before this story...
http://www.fieldlines.com/story/2005/4/16/42254/0713
Everything I have done with a 1/2HP is the same as he got with the 1/2HP.
I'll probably leave it wye connected, at least in the beginning.
I decided on a 36" blade, if time ever permits, but can not recall why I chose 36".
Re: ECM motor blade and wiring (3.00 / 0) (#2)
by iFred (ifred2006@yahoo.com) on Mon Jun 20th, 2005 at 08:15:31 PM MST
THANKS !!!
Just what I needed
Re: ECM motor blade and wiring (3.00 / 0) (#3)
by ghurd on Fri Jun 24th, 2005 at 09:16:04 AM MST
Let us know what you do with it and how it works out.
Still kind of afraid to tear into mine.
Rare as fish feathers around here, don't want to screw it up.
  84 Scoop users have viewed this posting.
· Also by iFred
