| The MTS input is for a 4 wire receptacle (240 volt). I have tied the 2 hot wires together (X and Y poles) to make it 120 volt. I have the neutral (from the transfer switch) to the neutral bus bar in the load center and the ground to the common ground bus bar. I turn off all other power and when I plug into the 3 prong outlet on the inverter the fuses on the inverter blow. I have checked all my load connections and they are correct so I am thinking it is something to do with the ground or neutral. Any ideas greatly appreciated. |
91 Scoop users have viewed this posting.
